ls6/fast intake
Old Sep 5, 2008 | 02:20 PM
daniel6718's Avatar
Default ls6/fast intake
whats the most restrictive part of it? the runners? or the t/b?
Old Sep 5, 2008 | 02:25 PM
stevegrizzle's Avatar
what came first teh chicken or the egg?
Old Sep 5, 2008 | 02:26 PM
00T/AWS6's Avatar
haha touche on that!!
Old Sep 5, 2008 | 06:24 PM
daniel6718's Avatar
thanks guys...
Old Sep 6, 2008 | 09:14 PM
daniel6718's Avatar
Old Sep 6, 2008 | 10:44 PM
you need to revise your question.
Old Sep 7, 2008 | 12:42 AM
snake charmer's Avatar
the flow on a ls6 intake runner is about 260 .the intake runeer of a stock non ported FAST is 270 . as far as the cfm of a 90mm tb i am not sure of . really the intake restricts the flow of the heads as most decent heads flow around 300cfm .
Old Sep 7, 2008 | 09:37 AM
teke184's Avatar
TPIS got almost the same gains as the FAST in power by using an ls6 intake modified with a 90mm TB
so my guess is the TB is the first restriction...then the runners
Old Sep 7, 2008 | 04:37 PM
davered00ss's Avatar
Moderator
I think he is referring to what area is more important to port?
If so, like said about the chicken & the egg. Both are needed to work properly together.
Old Sep 7, 2008 | 11:06 PM
daniel6718's Avatar
understood...what im actually getting at is there is less flow in the t/b area then we simply need to get more air comming into the intake...if its the runners then not much more we can do
if its the t/b area then nitrous guys would have a big benefit of spraying the nitrous after the t/b so its that much less that has to make it through the t/b...if its the runners the keep using nozzels and spray through the t/b
Old Sep 8, 2008 | 08:00 AM
Nightrydass's Avatar
we never did it yesterday; my boy forgot to do what i told him, do his homework, and he didn't have the coolant lines we needed.
We also never did the header install b/c the toolbag that was supposed to let us use his lift never showed up. . it took me over an hour to convince my friend that installing them on jack stands was a bad idea , esp considering that he DIDN'T soak the bolts the night before (like i told him to), we had NO air tools, and he was cutting off the rest of his exhaust...
