pully squeel
Old Sep 15, 2008 | 04:56 PM
shtnfrds's Avatar
Default pully squeel
so i washed my engine the other day and now one of the pullys that ahs the smaller belt on it is making GOD AWEFUL noises!! i ca spray it with wd-40 and it quiets down, but once i give it gas starts up again. is there one certain pully that does this often or do i just get to pick and hope i replace the right one? if i even need to replace it?
Old Sep 15, 2008 | 09:34 PM
McCs WS6's Avatar
your belt is prolly dried out.. get some belt dressing on it.. or buy a new belt.. my tbss belt was squealing and i kept sprayin it with dressing.. it wouldnt go away, i bought a new belt, no mor squeal
Old Sep 16, 2008 | 01:24 PM
ramairracer's Avatar
like he said a adried belt, dont use wd40 it may make the belt slip off, believe me i know
Old Sep 16, 2008 | 02:13 PM
ChevyRyda99LS1's Avatar
yep samething happened to me after a engine wash you are going to have to change it dressing does not help
Old Sep 16, 2008 | 04:38 PM
shtnfrds's Avatar
i'm not spraying the belt, that would make it slip, im only spraying the pully, which is why i would actually think it would be the pully?
Old Sep 16, 2008 | 04:42 PM
Brianbanscak's Avatar
took all my pulleys off and cleaned and repacked with grease, and noise wouldn't go away, then while car was at a shop, they traced it to the ac belt!!
Old Sep 16, 2008 | 07:22 PM
99345hp's Avatar
make sure you check the ac tentioner, because mine was bad and making the ac belt squeak like hell
Old Sep 16, 2008 | 08:18 PM
jayare98's Avatar
i would put money on it being the belt in the back. when i got the car they only replaced the serp belt and not the little one so my money is on that belt....
Old Sep 16, 2008 | 08:21 PM
BAMALS1's Avatar
I would say the A/C belt. I had the same issue a little while back and that was the culprit.
