LQ4 Block LS1 Camaro Accessories
So I ran into this little problem in my LQ4 build! I am using stock LS1 Camaro brackets and I stumbled across this boss on the block that is blank on the drivers side for the alternator! Has anyone drilled this out to run the camaro brackets!
Yeah I was wondering where that last bolt would go! I guess I will just have to run it with the front two bolts and the rear ear bolt! I am thinking that should hold up just fine! Thanks for the info!
So your just running two bolts the ear on the back and the one up front? You must not work on cars all day! I am going to drill that out! I dont need that thing walking around on me! To each his own! They put that hole there for a reason on the LS blocks!
Yeah the search function works great thanks! So if everyone makes it out to be so easy to drill it out, why havent you done so! I am just getting hated on here, thanks guys!
Engine is on the stand! I just got the bolts today and I should have a new Alternator tomorrow morning! I think I got it from here! I just dont see why people would want to run it with only one bolt up front and one in the rear!
Drill the one hole, and ignore the missing hole. The missing one is one of 3 bolt hole sthat hold a procharger onto the motor. Many a iron motor with prochargers making stupid power with that bolt hole not used. Not a single one has broken anything yet. If your running just accessories you have WAY less to worry about then a heavy, horsepower sucking blower hanging off the block.
I heave heard you CAN drill that last hole if your very careful about depth. I say leave it though.
