Fast 90 idle issues
Old Oct 3, 2008 | 11:36 AM
04gtod's Avatar
Default Fast 90 idle issues
I've not been able to get idle surge out completely since installing Fast90 with NW throttle body. Only have 220/224 cam and SD tune. Had no surging at idle with stock LS6 and ported stock TB before Fast installed. Any tricks?
Old Oct 3, 2008 | 12:23 PM
jmm98LS1's Avatar
Have you retuned since the swap?
Old Oct 3, 2008 | 06:54 PM
Vndcatr's Avatar
Maybe it has to do with the SD tune ?
Old Oct 3, 2008 | 07:27 PM
njc.corp's Avatar
no leaks or cracks anywhere?
Old Oct 3, 2008 | 07:53 PM
LS2tiger's Avatar
Did you recalibrate the Maf for the increased air flow ?
Old Oct 3, 2008 | 08:51 PM
thedak's Avatar
He has no MAF.
U r def going to need a sd retune after
installing a FAST
Old Oct 4, 2008 | 08:15 AM
Viper's Avatar
And a RAF idle tune.
Old Oct 4, 2008 | 10:56 AM
04gtod's Avatar
I had it tuned after the Fast install. What is a RAF idle tune?
Old Oct 4, 2008 | 01:16 PM
Viper's Avatar
Running Air Flow - let the car idle from cold to 215, turn off fans. Use the scanner with idle.cfg file, copy and paste values you find. Search on this forum or hptuners.com for the config file to use. What you are modifying is the base running air flow under the idle tab in hptuners.
