Idling problem with new intake.
Old Oct 10, 2008 | 09:02 AM
BIG_MIKE2005's Avatar
Mine did this when I swtiched to a ported TB for some reason. Is your TB sealed good & the blade fully closing? Is the TB blade drilled? From the sound of it a small tweak in your tune could eliminate your problems. On mine the problem was the TB blade had too big a hole drilled in it.
Old Oct 10, 2008 | 03:03 PM
BlkBird2000's Avatar
No I installed this ported throttle body with my ls6 intake and had no problems. It's gotta be the PCM. I can be stopped and idle is normal.. I can go 1mph and the idle goes crazy.
Old Oct 14, 2008 | 01:07 PM
A shop did what they call a "smoke test". Smoke came out from the back of the intake or around that area. They said it's a vacuum leak or some kind of knock off plate? charging me 80 dollars and hour. This intake is costing me more than 400 dollars lol
Old Oct 14, 2008 | 01:10 PM
ts why there was some RTV around the area. I had on installed there but removed it. I used the bolt to help secure the sensor but then ran a FAT bead of RTV around it to ensure no possible leaks. I'd be willing to bet thats the culprit. That bottom plate looked like it was sealed very well.
I didn't even think to ask you about how you mounted the MAP sensor.
Old Oct 14, 2008 | 11:40 PM
I cut some black tubing and slid on then the orange rubber thing on the tube and it fit pretty snug. I was thinking about that plate on the bottom of the intake today as well. I didn't check it either.
