hole above oil filter, size of plug needed?
you may want to post this up in the external section for better results.
This thread/tap requires an "R" letter size tap drill (0.339" dia-can be found at an industrial supply/machine supply shop).
Usually the casting hole thats already partially formed in the fitting may be slightly larger than this diameter towards the top of the hole, but will work if you don't tap it too deeply with the pipe tap. Don't tap any further down than 6 or 7 full threads from the top of the tap as the tap is tapered (I believe at 1.5 degrees) so the deeper you go - the wider the hole and this can cause the sensor not to seal correctly.
errr..... I got this info out of a box of Cracker Jacks.
http://www.a2stainless.co.uk/M16-x-1...-70_AICFQ.aspx
just not from the UK. LOL
unless there is something that MUST go there that I have randomly overlooked.
