can you get a LS1 over 350whp without opening it up?
and i know this cause that z28 is sporting my old stock gutted cats in that video.
STeven with the camaro is a memeber on here im not sure if oliver is...Ill let them tell u more about the cars.
Full Bolt-ons will get you around 350rwhp. Don't believe all the hype about these factory freaks. 9 times out of 10 something was done and not mentioned or the Dyno's where tweaked.
I tend to favor Mustang dynos over all others. More accurate IMO.
Typically Autos dyno 290ish, Manuals 305ish. You can estimate about 50rwhp for full bolt-ons putting you in that area.
you already have the ls6 intake so FAST isnt needed.
lid, longtubes, true duals, electric water pump, UD pulley should get you to 360-380rwhp easy.
dont waste your money on the following:
-new MAF
-smooth bellows
-anythign SLP offers
A mustang dyno shows lower #s than a dynojet, which dynos higher. IDK all the dif. types, some else can help with that. Accuracy is in the eye of the beholder IMO.
-new MAF
-smooth bellows
and with full exhaust369.6rwho 385rwtq sheets aswell
u sir can point the obvious huh?
lid gutted catts and some nice tips huh...
thats bout all it had.. i had a total of 160 dollars into the car
348 hp and 365 tq
on TEXAS SPEED AND PERFORMANCE's dynojet
![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
I guess all i'm saying is people need not get all wound out about dyno numbers be them high or low. Too many external factors effect the accuracy. I haven't even dyno'd my car because I see no point. I can compare mods with track times. I know i'm in the 340rwhp-ish area (full bolt-on stalled A4; M6 probably be 360rwhp-ish).
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
#34
LS1Tech Premium Sponsor
It's no problem to make 350rwhp with bolt ons & no fast Intake. I've personally engine dyno tested the Fast 92mm intake on a stock motor & it did pickup power, but it was only 9-10 if memory serves me correctly.
That being said determining how far past 350 is all based on your mods.
The TSP 1 7/8" headers made several more hp over a 1 3/4 header on our dyno test. If you ran a 1 7/8" TSP header to a good flowing exhaust/cutout.
Something Like This:
TSP 1 7/8" Headers
Off- Road Y Pipe
Cutout
Lid
85mm Maf
ASP 25% Underdrive Pulley
Ported TB (every last 1-2 hp counts!)
You could easily break 350rwhp.
My gut is you could even break 360rwhp with a electric cutout....
TSP 1 7/8" Headers
Off- Road Y Pipe
Cutout
Lid
85mm Maf
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
#35
If you are talking about at or corrected values to sea level, yes, you can get there without opening the engine up. Altitude corrected, since I'm over 5K feet elevation here, I came out at 362rwhp on a Mustang dyno. You can see my mods in my signature and I did have it dyno tuned with EFI Live. Being at altitude kills almost 80hp. Sure is a gas when I drive the Power Tour and get down in the nice thick air.
