is this cam to big
Old Oct 16, 2008 | 08:19 PM
bluebird00's Avatar
Default is this cam to big
a 236/236 duration 585/585 lift is this cam any good??
if so could it be used on stock heads and could i use the
dual springs for it??
or should i go with the f1 cam 230/226 duration 591/569??
any advice is apreciated!
Old Oct 16, 2008 | 11:58 PM
bluebird00's Avatar
anybody??
Old Oct 17, 2008 | 12:08 AM
ABQ99TA's Avatar
It is not to big. I've never had it but I'm sure it is ok. I would look around more before you jump into any cam.
Old Oct 17, 2008 | 12:17 AM
bluebird00's Avatar
ive been doing some research on the lpe gt2-3 cam?
Old Oct 17, 2008 | 07:22 PM
bluebird00's Avatar
bump!!
Old Oct 17, 2008 | 08:12 PM
purdueranger's Avatar
Who's 236 cam is that? you can use it on a stock head, remember that these heads flow a lot better than old school SBC heads from the factory. I would mate either one of those cams up with a set of Patriot gold dual springs. Also do you know what set of lobes that 236 cam is on?
Old Oct 17, 2008 | 08:30 PM
bluebird00's Avatar
all i know its a z1 cam but im leaning towards the f1 cam which is 226 230
569 591?
Old Oct 17, 2008 | 08:31 PM
bluebird00's Avatar
they say a lot of cars dyno over 400hp with stock heads and a tune with the f1 cam.
Old Oct 17, 2008 | 08:47 PM
66deuce's Avatar
how much power does it make at 3000rpms?don't get caught up in peak #s..really,how much time will your motor spend at 6000+ rpms?get a cam with a broad powerband if your talking a DD...
Old Oct 17, 2008 | 09:13 PM
BlackScreaminMachine's Avatar
Internet Mechanic
Well posting the brand of cam would help, or like said the cam lobe specs are equally as important.
Old Oct 17, 2008 | 09:33 PM
bluebird00's Avatar
its the speedtek cam.
Old Oct 17, 2008 | 09:36 PM
bluebird00's Avatar
it has Lobe separation 112 with 4 degrees advance.
Old Oct 17, 2008 | 10:58 PM
willyfastz's Avatar
Restricted User
Not the best cam if you have to have a shelf cam the F1 is probably a better choice with a beehive spring NOT a duel spring setup.
Old Oct 17, 2008 | 11:21 PM
bluebird00's Avatar
thanks willyfast im picking up the f1 tomorrow!! so whats the deal with the dual springs?
Old Oct 17, 2008 | 11:24 PM
bluebird00's Avatar
can i use the stock retainers and seats and lock with the 918s??
Old Oct 18, 2008 | 12:46 AM
KMS.1320's Avatar
the F1 is a reverse split? eeewww... don't buy that. I have no idea who thought it was a good idea to run a reverse split on an LS engine. I can't think of a single instance it would be the choice cam.
Old Oct 18, 2008 | 09:36 AM
willyfastz's Avatar
Restricted User
Yeah you can, I would recommend the Pac 1218 spring package though over the Comp 918's. Set the install height up properly and you should have a setup that's reliable and makes good power.
Old Oct 18, 2008 | 10:05 AM
RZRSEDGE's Avatar
I personally have not ran a reverse split cam; but TR's 230 cam is a 230/224 on a 111 and there has been a bunch of cars have great success with it. I think that MTI also had good success out of reverse split cams. That's just to name a couple. I believe that Predator Z is also a firm believer in the the TR 230, may be wrong though. Anyway, to the original poster, Good luck and there's several happy people with the F1!
Old Oct 18, 2008 | 01:35 PM
willyfastz's Avatar
Restricted User
I didn't look and see the F1 is reverse split, don't run it.
http://www.hardcorels1.com/vbulletin...=reverse+split
Old Oct 19, 2008 | 02:27 PM
bluebird00's Avatar
ok found a came i like but the lsa is 111. is that going to be to choppy for a dd?
its the comp cam 228
