changing rod bolts?
Old Oct 28, 2008 | 06:53 PM
C Murda's Avatar
Default changing rod bolts?
ok so ive read about the stock rod bolts being a weak link in 500+hp and higher RPMs so im tempted to change mine to an ARP set. now the only thing holding me back is that ive read somewhere on here that the rod caps are actually toothed in a way? so that they mesh with the rods and arent actually perfectly flat for some reason...and if you remove them they wont go back together exactly how they were which would cause bearing problems? anyways what should i do?
Old Oct 28, 2008 | 06:54 PM
studderin's Avatar
you change them one at a time
Old Oct 29, 2008 | 09:31 AM
C Murda's Avatar
ahh makes sense...thank you. now what are a good set of ARP bolts?
Old Oct 29, 2008 | 09:50 AM
99T/AMAN's Avatar
katech makes a set that fits right in no problem.
Old Oct 29, 2008 | 04:49 PM
studderin's Avatar
I have a set of arp Im selling PM me
https://ls1tech.com/forums/showthrea...144&highlight=
Old Oct 29, 2008 | 09:02 PM
SOMbitch's Avatar
Katechs are much closer in size and weight to OEM than heavy ARP's and is the only ones I would do without getting the rods resized. DEFINITELY DO THEM ONE AT A TIME If you decide to move forward. Some have run the ARP fine and others have had failures. It is a crapshoot IMHO. I decided to take my chances with the stock 98's and shift at 6500 even though I am leaving a little bit on the table. Their is a recent poll thread around here on this very subject you may want to search.
Old Oct 29, 2008 | 09:12 PM
socmguy's Avatar
Restricted User
I put in the ARPs and have been to 7K several times. Cheap insurance if you ask me. Its a smart thing to do.
Old Oct 30, 2008 | 10:18 AM
C Murda's Avatar
thanks for the info guys now its just deciding between ARP and katech...i heard that the newer 01-02 ls1s had come with stronger factory rod bolts and if so, how much stronger are the katech rod bolts?
Old Nov 1, 2008 | 12:56 PM
99T/AMAN's Avatar
i think its that they fit better without having to make the rod bolt holes bigger, i think i read that awhile back!?!?!?!
Old Nov 1, 2008 | 08:39 PM
Hotrod406's Avatar
I used ARPs on mine. I did 7 rods one bolt at a time but I had one cap off to check bearings so I just put that cap back on the way it was and installed the bolts. I've got 5000 miles on it and I routinely shift it at 7000 rpm with no issues.
Old Nov 2, 2008 | 08:19 AM
studderin's Avatar
https://ls1tech.com/forums/generation-iii-internal-engine/946074-poll-who-s-had-stock-rod-bolts-fail.html
I dont think Ive eveer heard of a stock rod with arps swapted in, the rod bolt failing.
Old Nov 2, 2008 | 09:22 AM
SOMbitch's Avatar
Originally Posted by studderin
https://ls1tech.com/forums/showthread.php?t=946074
Only had to go down 4 posts to find one in ur link I didn't read any further. It's a crapshhoot IMO.
