Installing heads and cam on a 2002 camaro with 54,000 mile what should I replace
i got my ls2 gears and chain as a set, for piece of mind bc my motor had 100k. also, the melling 295 is not a high pressure unit its a standard pressure unit. its basically a factory replacement. i swapped mine even though i had good oil pressure to start and it ended up being about the same with the new pump.
the other pump is equipped with a higher pressure spring and suppose to mover more volume and psi
Was gonna run last night for Freaky Friday and developed a miss at 5k. Been waitin to pick up some used DR's cause first gear is useless even with a roll in throttle. I will try to figure this out today and prolly run at T & T next Thursday even if it is on street tires.
I used stock MLS GM gaskets for my heads and I used 7.425" pushrods at the advice of TSP when I was talking with them on the phone and haven't had any issues at all. As stated, picked up a LS2 chain only and replaced my trays while I was in there too. I did pony up for the ARP Head Studs, but that was just me being paranoid and everything else. Ported LS6 oil pump topped everything off. Alas I have no times at the track since all my money went into H/C/I that my factory clutch is soggy as angel hair pasta right now. I will remedy that next season, I hope.
