What will I need to do to break 7k?
"Also, I agree that a bigger cube motor will be cheaper and make more power."
Now if he was running in a class that restricted his cubes then it's a different story.
It's not like you can just slap components together and spin 8k all day long. There are serious things to consider when building an engine to rev up to the upper rpm range and stay there. Components that can handle high rpm, such as a lightweight valvetrain, a good oiling system, a cam and air induction system that can support such rpm has to be carefully picked, assembled and tested. I just don't see a setup being streetable in the upper rpm all day long if you find yourself having to hang at 4k just to cruise around. Sounds badass, but wanting, needing and realizing something are different things.
Anyways...
The 333 idea isnt about maximum hp. Its about standing up for a personal theory, more proving that the CI/HP ratio is possible in something that can be driven on the street. Now believe me, if I could use more cubes I would But as far as it goes I dont have a choice. Other than a completly custom crankshaft I cannot achieve a 1.92 rod ratio. I mean seriously, one step up in crank would mean I need to use 7" rods, and that just wouldnt fit...unless I went crazy (and had the cash to do so). I have thought it out. 4.8L Crank and Rods worked over, paired with a 6.0L block; but unfortunatly it would still need custom pistons and believe me I REALLY wish I could use the factory 6L pistons but oh well. All in all it comes out to 10k, in the car. According to my math. However that doesnt include supporting mods like any upgrades to the axle tranny and chassis.
Whew...
So what I have come up with is that I will need shaft mounted rockers and quite possibly a dry sump oil system. Anything else?
on top of that rather than answering questions about valvetrain.. since they dont know they just ridicule. whats the point in posting? if i listened to people tell me "you cant do that".. geeze...
Why spend more money to make less power just so you can say you rev it 800rpm higher?
A 408 with a turbo would **** all over a 333 with a turbo from idle to 7000
And be cheaper?
And be faster at the strip?
And drive better on the street?
Its ok to be different, its just dumb to be poorer and slower
1) To get the ratio you want, you are limited to a short stroke, and therefore limited on displacement.
2) Mathematically speaking, more RPM's does equal more power, supporting mods assumed, but generally at a greater cost per HP than other tried & proven combos
3) Since the goal seems to be primarily streetable power, most people have a problem spinning a V8 powered street car much over 6,500. Reliability becomes a concern.
Recommended reading - Jason @ Katech on High RPM's - an extreme example at 12,000 rpms, but you get the idea. Whole thread here
Another good read - relationship between rod ratio and port volume
I'm guessing you've already seen this one, but if not - What are the advantages/disadvantages of longer connecting rods?
Erik said it best here:
Smoky also noted to the guy that asked him about destroking for power that they had all cheated by building larger engines than were allowed including Roush and many in NASCAR but no one ever cheated by building a really small motor !!!!!!!! (with super long rods) .........enough said.
A 402 or better yet a 416 (cheap displacement) would be considerably stronger than a 333 CID build evaluating AVERAGE high RPM power (the portion of your tach you would use at WOT banging gears), and if we were to look at the bottom of the curve it would be a ridiculous comparison even more lopsided.
You think better rod ratio can make up for 80-100 CID?? Its just not a wise allocation of funds IMO but Im all about pulling out the
and sitting back to watch this deal go down.Build a bigger motor with the same turbo and have a more reliable piece thats enormously more fund to drive around town with an extra 100 plus foot/lbs at your discretion. The money you save in high RPM specific parts can pay for other go fast goodies or driveline upgrades as well.
Small high winding engines are purpose built and better suited in specific racing applications with deep pockets to back the project.
Just my .02 to add to all the others here as well who have shared similar opinion.
Tony
PS....Whats funny is I swore it was Smokey Yunick who almost said just the opposite....something along the lines of the right connecting rod is the one that fits beteen the crank and the piston....LOL Im serious btw and I may be completely off base here but I would like to see some quotes from Smokey on that topic. I dont think he was obsessed with a long rod but I could be wrong. Personally I will take displacement all day long over rod ratio if we are building engines for 3500+ pound street/strip cars. As long as the rod ratio is reasonable (1.5 ish or better), I will take the displacement every day and twice on Sunday
Also this engine isn't for so much street as the drive to the strip. The car isnt going to be driven very much.
I'm not so kind. What you're trying to do under these circumstances is pointless. You're trying to prove a theory from the 60s that has been beaten to death and proved flawed. You already have your answer of what would it take to for an LSx engine to survive over 7000rpms. Let this thread die along with your horrific idea.
