ticking
Old Nov 10, 2008 | 09:09 PM
coryprine's Avatar
Default ticking
heres a really stupid question but would longer pushrods eliminate a ticking valvetrain sound?.. bone stock setup btw
Old Nov 10, 2008 | 09:13 PM
Damian's Avatar
LSX Mechanic
Need to give me details about the car...
Stock engine? Modified? How many miles?
There's a lot of things that can create a "tick" sound. Exhaust leak, check valves in the AIR tubes going bad, clogged up pushrod not allowing oil to pass through, etc etc etc
Old Nov 10, 2008 | 09:15 PM
coryprine's Avatar
01 camaro 138xxx miles been having a ticking sound that increases with rpms for a few weeks... first cpl days it went away once warmed up then it was always there... i was thinging lifters... i changed all lifters and pushrods... no change... my mechanic is thinking worn out cam... im just not feeling it... car drives good just the damned ticking.... i dont have my own video of it but heres one on youtube that sounds identical... plllllz help fellas..
http://www.youtube.com/watch?v=VeY_3HcC1MI
bone stock car btw..
Old Nov 10, 2008 | 09:34 PM
Damian's Avatar
LSX Mechanic
So the heads have been pulled off the engine before?
Replace the check valves in the AIR tubes. These can create a ticking noise. If you're not familiar with them, this is what they look like however yours are more than likely black in color..
A leakdown test would also be a good idea to make sure no valves are bent.
Old Nov 10, 2008 | 09:36 PM
coryprine's Avatar
already checked the AIR system... sorry didnt mention it before.... could it still be a lifter issue?....maybe one still has air in it?.... or is my cam fukd...lol
Old Nov 10, 2008 | 09:58 PM
Damian's Avatar
LSX Mechanic
Doubtful it's the cam. Thats a rarity unless you have a valvetrain problem somewhere else.
Did you replace the lifters with new ones? That shouldn't be the problem if so.
Keep in mind the injectors also put out a "tick" sound.
Old Nov 10, 2008 | 10:24 PM
novaflash2002's Avatar
is it a high pitched tick or a low pitch. it sound like a crazy question, but i have seen them shrink a piston over time and make almost the identical sound.
Old Nov 11, 2008 | 05:10 PM
coryprine's Avatar
it sounds like tapping a pen on a desk...lol
Old Nov 12, 2008 | 01:01 PM
coryprine's Avatar
bump...
Old Nov 12, 2008 | 08:24 PM
Batmobile00's Avatar
check all rockers and don't forget to check for exhaust leaks
