which year model cars w/ 243 heads had the good valves
Old 05-06-2009, 01:10 PM
00Camary's Avatar
Originally Posted by Scoggin Dickey
You'll be fine.
K .... all this chatter made me a little nervous that the sodium valves were ideal for a stock setup and maybe not as much for bigger cam and springs.
Thanks
Old 05-07-2009, 12:09 AM
sunsetorang01TA's Avatar
def some good enough in this thread! So would sodium filled valves be ok for a more wild setup?
Old 05-07-2009, 01:33 PM
Gary Z's Avatar
The lightweight LS6 valves are not fragile. I have stock LS6 243 heads and valves with PAC 1518 springs. My engine survived a https://ls1tech.com/forums/drag-raci...2-1-shift.html that hit 7800 rpm without any damage.
Old 05-07-2009, 01:40 PM
00Camary's Avatar
Rut roe.
Old 05-08-2009, 12:43 PM
haha wow. that serious!
Old 07-30-2009, 11:59 AM
lovescamaros28's Avatar
Originally Posted by badmfkr
I'm assumming that the sodium filled valves are lighter reducing the the force it takes for them to go up & down so you get more power w/ lighter valves?
is this the reason to get sodium filler valves?
so the 243 w/ sodium valves stops at 04 Z06 because the 05 had LS2?
Thanks
Sodium filled valves are lighter,but they also reduce the temperature of the valve and prevent warpage.
Quick Reply: which year model cars w/ 243 heads had the good valves
