G5X2
Old Sep 20, 2003 | 01:56 PM
SSEUL8R's Avatar
Default G5X2
Anyone know the numbers on this cam? I've heard of it lots of times, but I've never known the lift and duration on it. Thanks
Old Sep 20, 2003 | 02:05 PM
Phil99vette's Avatar
7 Second Club
Default Re: G5X2
232/240 .595 .605
Dont run 987 springs
Old Sep 20, 2003 | 04:03 PM
Country Boy's Avatar
Senior Member
Default Re: G5X2
232/240 .595 .605
Why not?!?!
Old Sep 20, 2003 | 08:10 PM
The Juggernaut's Avatar
Default Re: G5X2
232/240 .595 .605
actually it's .609 on the exhaust side.
This cam kicks ***.
Old Sep 20, 2003 | 10:41 PM
Ramair346's Avatar
Default Re: G5X2
Yeah, this cam is the mutt's nuts. I'm bummed because they're coming out with a new version, not I need to do another cam swap. Well, they're "testing" it, so I guess I've got time. I wish all vendors tested things before they sold them. Lou rules!
Old Sep 21, 2003 | 06:28 PM
2001CamaroGuy's Avatar
Default Re: G5X2
232/240 .595 .605
Why not?!?!
Valve Float
I talked to Lou about this (have 987s with my TR224). He told me the 987s will "work" if I don't take the car past 6500. Above that the 987s WILL float. His suggestion was to upgrade to 977s (which will require Comp R lifters....factory/GM lifters will not work with the 977s spring pressure)
Old Sep 21, 2003 | 09:30 PM
Senior Member
Default Re: G5X2
Hummmmm.......
Ive spun mine to 7100 a few times so far and no problems.. I may have to look into this. Thanks!
Old Sep 21, 2003 | 09:36 PM
BYBYC5's Avatar
*Bad Trader*
Default Re: G5X2
uh ya, all the other vender just dream up specs and call up comp to make em huh?
Old Sep 21, 2003 | 09:51 PM
Louis's Avatar
Default Re: G5X2
Carl, You have the Comp Rs anyhow right?
Email me if you want your Installed height on your springs
Louis
Old Sep 21, 2003 | 10:04 PM
Senior Member
Default Re: G5X2
Hey Louis... just the man I was going to email
I do have the comp Rs, but they are at the stock preload because I dont have adjustable rockers yet
Email on the way....
Old Sep 21, 2003 | 10:29 PM
Ramair346's Avatar
Default Re: G5X2
I wouldn't say they dream up specs, but making sure a package has P to V clearance or works with stock components seems to be a problem for some as of late.
Old Sep 21, 2003 | 10:44 PM
7 Second Club
Default Re: G5X2
I have bent 8 valves from running these **** poor 987s. They are perfectly fine for <230 XER but when you get this big your going to float over 6-6500 depending on install height. I am sure you can set them up at 1.700 and make them work but your going to be close to coil bind. 977s are the way to go but you need Comp R lifters for any spring over 375-400lbs over the nose of the cam. If your running a 232/240 XER with 987s and rev your car past 6-6300 on a regular basis you may have bent valves already. My car started slightly stuttering at low speeds and thought it was due to the big cam but it was slightly bent valves. I would like to introduce Mr. floating valve to Mr. Piston...<Wack>
Phillip
Old Sep 22, 2003 | 08:43 AM
v8maro's Avatar
Default Re: G5X2
I use comp 978's, for anything less than .600 lift, they are good, worked heads let them sit at 1.850" installed.
I would say the 977's or the dual rev's are the way to go with the g5x2
-Steve
Old Sep 22, 2003 | 08:47 AM
gomer's Avatar
Default Re: G5X2
Has anybody had the ***** to try the G5X2 with 918's yet?
