vindicator camshaft ????
Old Nov 16, 2008 | 06:36 PM
layz's Avatar
Default vindicator camshaft ????
i recently bought a vindicator cam...240/244 605/596
i was wondering will in fit in a 1999 t a stock motor without flycutting.... car has ls6 intake and long tubes...need help asap
Old Nov 16, 2008 | 06:55 PM
memphisTa's Avatar
should
Old Nov 16, 2008 | 08:45 PM
Super Speed's Avatar
Depends, on some cars its fine on others it hits.
Old Nov 16, 2008 | 08:50 PM
KMS.1320's Avatar
Clearances are so tight that small variances in the valvetrain or any valve float at all can cause the valves to hit the pistons. Be sure to check, it's recommended with that cam.
Old Nov 16, 2008 | 08:59 PM
00SSLS1's Avatar
why would you buy one without knowing first?
Old Nov 16, 2008 | 10:21 PM
98blueSScamaro's Avatar
it's very close thats why i went with 243 heads on this cam more room.
Old Nov 16, 2008 | 11:59 PM
Evans752's Avatar
Does the 243 (LS6) heads give you more piston to valve clearance because I was always under the impression that it would have the same or a little less because with they have the extra compression they say they have but I don't know for sure but just assumed but I never checked or compared them.
Old Nov 17, 2008 | 12:43 AM
KMS.1320's Avatar
nope, less room.. 243's have a smaller combustion chamber than 241's or 853's.
http://www.smokemup.com/tech/ls1.php
Old Nov 17, 2008 | 01:09 AM
-Joseph-'s Avatar
LSxGuy widda 9sec Mustang
With stock valves and no milling it should be identical PtoV between LS1 and LS6 heads. Combustion chamber sizing doesn't dictate PtoV unless milled to achieve that size, LS6 heads have a different shape combustion chamber to gain compression over the LS1 heads.
Of the Vind. cams I've seen, the intake clearance was tight due to the +4 degree's advance and using a 240 duration lobe, if the camshaft was degree'd and installed retarded or at 0 advance, it could probably squeak by a little safer, but that also changes the camshaft characteristics somewhat. I'd probably just flycut to be safe.
Old Nov 17, 2008 | 09:13 AM
TXZ28LS1's Avatar
my buddy is running the vindicator cam on his 98 SS with stock heads and ls1 intake and untuned..
Old Nov 17, 2008 | 09:18 AM
Chrome355z's Avatar
Old Nov 17, 2008 | 09:47 AM
BIGB4015's Avatar
Its tight! The shop I go to did one and checked the ptv clearence it was .27 with stock Ls1 heads and head gaskets.
Old Nov 17, 2008 | 10:24 AM
bboyxclub's Avatar
What would be a safe margin to go with on PTV clearance??
Old Nov 17, 2008 | 10:32 AM
Chrome355z's Avatar
"Safe" is typically no less then 0.080" for a hydraulic roller.
