Starter problem.....stuck at school help!
The Ignition Switch is ontop of the Steering Column, and you have to drop that to get to it. It's easiest to pull it straight out.
Take your lower Drivers side Dash apart, and disconnect everything off of the Steering column. Then go under the Hood and take the Bolt out of the Linkage next to the Headers. Go into the Car under the Dash and you will see 3 Bolts on the Fire Wall around the base of the Column, pull them out. Then follow it up, and you will see 2 on each side of it holding it up, pull them out while supporting it. Once they are out it will literally fall in your lap. Disconnect the Connectors that you see going to a white plastic thing, that is the Ignition Switch. Then just guide it out.
The IGN Switch is pretty quick to change, just make sure the Rod goes in it's spot.
if it works ill post more info on how i fixed it
i think the dashlights won't come on cause you blew the 50a ignition fuse.
im trying to figure mine out right now, some kinda short bad relay or solenoid
