Torquer v.2 Question
Old Nov 20, 2008 | 01:11 PM
jmmullin's Avatar
M6, stock 3.42 rear
Old Nov 20, 2008 | 03:23 PM
TLUZLS1's Avatar
Originally Posted by wht01ws6ta
How many miles do you have on the oil pump? I had over 80K so I got their ported LS6 pump without giving it much thought since I was going this deep into a build.
I just replaced my stock chain with the 30 dollar LS2 chain, not sure about the kit.
I have 94k on mine. Ill probably go ahead and replace it, i just read on the stickies that it's a good idea on 98-00 cars, wasn't sure about my 02.
Old Nov 20, 2008 | 03:41 PM
FlashLCD33's Avatar
It's $130, it has higher miles, and you're in there already. Why not IMO.
My '00 has 79k miles and I'm replacing the pump with a TSP ported unit when I order my Torquer. Cheap insurance, IMO. Same with a $30 timing chain.
Old Nov 20, 2008 | 04:31 PM
silverLSWON's Avatar
Originally Posted by RyderTA
Good hell! How did you pull that off? The best milage i've gotten with it so far is 21.
i did it on the way down to the lsx shootout. believe me i babied it. that was my best mpg, my worst on that trip was 24.3.
if you have a low mileage 01 and never ls1/ls6. i wouldn't worry about the oil pump and timing chain. and 00 and older or above 35k, i would replace the oil pump(even if it's stock ls6 one) and upgrade to the ls2 timing chain and gears. also DEF get a new oil pump o ring. i use the red ones from gm
my car has tons of low end but i also think the 4.56's has something to do with it
Old Nov 21, 2008 | 10:39 AM
TLUZLS1's Avatar
130 for the ported unit? Where?
