which TSP cam is the best for Performance
Old Nov 19, 2008 | 05:29 PM
02 T/A 984's Avatar
Default which TSP cam is the best for Performance
i currently have a 02 M6 T/A with a Torquer v.3 would like to try another cam and see if i could get a little more performance i like the service at Texas Speed so i would like to go through them.....please help
Old Nov 19, 2008 | 05:34 PM
KBG's Avatar
KBG
MS4 for all out top end horsepower
Old Nov 19, 2008 | 05:38 PM
Jon@Texas-Speed's Avatar
What are you looking for out of the cam. Are you looking for a max effort cam or are you looking for more hp/tq in a certain part of the power band? Give me some more details on what you are wanting and we can get a cam spec'd to meet your needs!
Jon Reynolds
Texas Speed & Performance
Old Nov 19, 2008 | 05:47 PM
02 T/A 984's Avatar
i was a little dissapointed in my results from my Torquer V.3 only put down 383rwhp.....363TQ....i was hoping to get more like 400-410rwhp....wanting to get a cam that has alot of low end power for acceleration for 1/4 mile racing....but at the same time i want a cam with good driving manners b/c the car is a daily driver.....also to help u the other supporting mods are Pacesetter LT, TSP ORY, and a SLP lid
Old Nov 19, 2008 | 06:35 PM
F8L_LS1's Avatar
maybe the answer is not in buying a new cam but in upgrading your current heads.
the heads will not harm drive-ability and will definitely get you to your goals.
you could even go with a smaller cam and the heads will still get you to where you want to go (depending on which heads you get)
Old Nov 19, 2008 | 06:37 PM
santiago's Avatar
i agree
Old Nov 19, 2008 | 07:34 PM
5.3LJimmy's Avatar
Swapping that cam for a different one is not gonna make a huge jump in power. What type of dyno and what other mods do you have?
Old Nov 19, 2008 | 07:44 PM
02 T/A 984's Avatar
i believe the heads comment is right.....other mods AT THE TIME OF DYNO....Pacesetter LT's....... TSP ORY..... Torquer V.3.....after the dyno i've added a lid....which i dont know how much that will add but im guessing bout 10rwhp
Old Nov 19, 2008 | 07:53 PM
5.3LJimmy's Avatar
Are you still running the stock catback?
Old Nov 19, 2008 | 07:55 PM
02 T/A 984's Avatar
yes its stock
Old Nov 19, 2008 | 08:07 PM
5.3LJimmy's Avatar
You definitely have some room to open up the power potential of the current setup with a few more bolt ons. The lid, a good free flowing catback, a ported throttlebody, and underdrive pulley will get you in the area of 400-410HP. Heads will likely put you above that, but won't be optimized until you get all the supporting mods.
Old Nov 19, 2008 | 08:09 PM
danger ds's Avatar
I agree 100% you need the supporting mods to get the most out of the cam
Old Nov 19, 2008 | 08:15 PM
02 T/A 984's Avatar
what cat back would u recomend?
Old Nov 19, 2008 | 08:22 PM
danger ds's Avatar
TSP true duel's, Magnaflow 3in cat back, or put in a cut-out after the Y pipe which is about 150 bucks.
Old Nov 19, 2008 | 08:24 PM
5.3LJimmy's Avatar
I like the magnaflow as well.
Old Nov 19, 2008 | 08:29 PM
bigfatls6's Avatar
You already have the right cam. I am guessing you have the ls6 intake on your car. You definetly need to work on your exhaust considering that cam really needs a free flowing exhaust. You can buy a cut out for like $40 and have it welded in at any exhaust shop for $50 and that would probably put you up to the 400+ hp mark easy. Then get you an under drive pulley and some stage 2.5 5.3 heads and your looking at 430-440 rwhp easy
Old Nov 19, 2008 | 09:13 PM
ABQ99TA's Avatar
Get the cat back with that and the lid you'll see a few more ponies I run that cam with cats and I put down 404, when it was getting tuned he told me I would pick up about 5-7rw if I did not have th cats. Who tuned it that could be an issue also.
Old Nov 19, 2008 | 09:18 PM
rsodeputy61's Avatar
Nothing wrong with your choice of cam. You just need to put together a better "overall" package...
Old Nov 19, 2008 | 10:35 PM
67camaro's Avatar
The stock catback doest even flow enough for the stock ls1 so its really choking your setup. I say add an electric cutout and leave the stock catback on with some nice tips.
Old Nov 20, 2008 | 10:15 AM
Brian @ Texas Speed & Performance's Avatar
LS1Tech Premium Sponsor
You definitely need a catback. Back when my car only had a lid, I added one of our Rumbler catbacks and it picked up ~15RW. Imagine what kind of gains you would see with a cam car. There are quite a few catbacks to choose from that flow really well. Hooker, Magnaflow, our Rumbler catback, and our Rumbler True Dual system all flow really well. You really shouldn't have a problem reaching your goal. Just finish off the bolt-ons. The next step up for a cam would be an MS3 or MS4. You would see a gain out of either one over the T3 you have. I would also look into a set of heads. A head swap would give you more power than a cam swap would. The PRC 5.3s would work well with the T3.
Brian
__________________
01 NBM Z28- A4 w/3.23s, TSP Black Lid, Hooker Catback, Pacesetter Headers w/ORY, ASP Pulley, Ported Throttle Body, TSP Torq. v3(231/234) Camshaft, TCI 4400, PRC Stg 1 Heads
www.texas-speed.com
(806) 866-0734
