Stroker's come in
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Jon
https://ls1tech.com/forums/10645372-post85.html
Were the springs removed and the seals mentioned in post 85 installed?
Several of you TSP reps said in the beginning, "there is no way that much oil will be consumed through valve seals."
I guess the heads will be coming off within the next week and i'll be sending them back.
If you want to send us the heads for inspection you are definitely welcome to do so. We would be happy to inspect them, fix a problem if there is one and get them back to you as quickly as possible. In the mean time, you might throw your factory heads back on and see if the problem is fixed. I would be interested to see if anything changes.
Jon
welcome to building cars, its expensive and sucks...
And you have obviously succeded. I have spent about $275 in the past month addressing the problem, which still isn't fixed. I've called in a couple of favors from a friend or it would have cost me a good bit more.
At this point, it is much more feesable for me to get a refund and just buy another set of heads. I don't want to pay shipping TO and then FROM TSP again or pay to have an experienced person replace the seals
I'm sorry, but I think i'm ready to try a new set of heads. The PRC's will be pulled off as soon as I have time.
Jon
Jon
If he does have a blow by issue then how do you imagine the oil is getting on top of the valves now that there is a catch can in place?
Jon
Are you saying then you would pay for HIS time and HIS labor if he knew how to work on HIS car? I mean, I would think of REGUARDLESS of who is doing the work, that if you sent a faulty part, you would cover their time/labor. Again, that is saying IF it is a faulty part. I do know that your heads have not been confirmed as the problem, and I do know that from what I have read you guys do bang up work in most cases. I would think that IF it is your fault however, that some type of compensation is in order for all of the trouble this guy has gone through. If that is not your normal practice, it should be. Again, this man went through the trouble of installing a part that you sent him, and IF it is bad from the get go, his time (or WHOEVER did the install) is worth being compensated for.
