final say on this.....
Old Sep 22, 2003 | 11:39 AM
RAMnGO's Avatar
Default final say on this.....
ok i have some pics of my heads that i put on my car and i would like to know if you look at a 5.7l head and a 5.3l head can you tell a difference between them by the combustion chambers alone?? i've got myself into quite a scenario here and i need to start with the heads...
Old Sep 22, 2003 | 04:07 PM
BergerMan's Avatar
Default Re: final say on this.....
Check the casting #'s, They will tell you EXACTLY what you have. It is a 3 digit # cast into the corner of each head.
Here is a list of a few casting #'s:
853 97-00 aluminum 5.7
241 01-03 aluminum 5.7
243 LS6 aluminum 5.7
852 and 706 99 and up 4.8-5.3 truck heads
873 99-00 LQ4 6.0 iron heads
317 01 and up LQ4 6.0 aluminum heads
035 02 and up LQ9 6.0 aluminum heads
Even more info:
Casting Number 241
Head: 1997+ LS1 5.7 Litre Passenger Car
Material: Aluminimum
Part Number:
12559853 (1997-98)
12559853 (1999-00) (not sure why same PN)
12564241 (2001-03)
Combustion Chamber Volume: 66.67cc
Compression Ratio: 10.1:1
Intake Port Volume: 200cc
Exhaust Port Volume: 70cc
Intake Valve Diameter: 2.00 inches
Exhaust Valve Diameter: 1.55 inches
Casting Number 243
Head: 2001 LS6 5.7 Litre Passenger Car
Part Number:
12564243
Combustion Chamber Volume: 64.45cc
Compression Ratio: 10.5:1
Intake Port Volume: 210cc
Exhaust Port Volume: 75cc
Casting Number 706
Head: 1999+ LR4 4.8 Litre Truck
1999+ LM4 /LM7 5.3 Litre Truck
Part Number:
12559852
12561706
Combustion Chamber Volume: 61.15cc
Compression Ratio: 9.5:1
Intake Valve Diameter: 1.89 inches
Casting Number 373
Head: 1999-2000 LQ4 6.0 Litre Truck
Material: Cast Iron
Part Number:
12561873
Combustion Chamber Volume: 71.06cc
Casting Number 317
Head: 2001+ LQ4 6.0 Litre Truck
Part Number:
12572035
Compression Ratio: 10:1
Old Sep 22, 2003 | 04:31 PM
Paul F's Avatar
Also on the underside of the head above the CC it will have 4.8 or 5.7.
Old Sep 22, 2003 | 05:31 PM
Visceral's Avatar
In that table either the 373 or the 317 compression ratio is wrong, since the CC's are the same size for the same motor.
chris
Old Sep 22, 2003 | 05:36 PM
BergerMan's Avatar
chris
Yup, the cc's are the same, its the pistons that are different which raised the compression to 10:1 in 2001+. Combustion chamber volume isn't the only variable in calcualting the compression ratio.
Old Sep 22, 2003 | 08:00 PM
RAMnGO's Avatar
ok first off i have pics of the new heads combustion chamber...the number on the head is 862...when i looked at my old heads and compared them to the new heads combustion chambers i mean ray charles could have seen the difference...and thats where i'm gonna stop....
Old Sep 22, 2003 | 09:17 PM
BergerMan's Avatar
RAMnGO, I'm still not sure what you are looking for here so send me a message and maybe I can help you out with your problem.
