What mill on 5.3 heads would you reccomend for G5X2 cam?
Re: What mill on 5.3 heads would you reccomend for G5X2 cam?
No mill will be safe with stock 5.3 heads and gaskets with a 112lsa 108icl cam(the standard one). It's petty much meant to max out the opportunity and clearance of a stock head and gasket. Since yours is a 114lsa, if you have a 110icl(4 degrees advanced) you should be able to mill .010" max.
Bryan
Bryan
Why mill???? If you go with the right head porter...he should be able to get 11:1 CR unmilled.
Would you be able to sink the valves a little and maybe free up some room to mill a tad???
