Building a LS1 for a stang
Old Nov 23, 2008 | 11:32 AM
LoNSlo02's Avatar
Default Building a LS1 for a stang
and ive got a few quesitons... as you can see im putting a ls1 in my coupe. i bought a block and crank the other day for 200 bucks(all standard). Im looking to build a twin turbo set up for this car to make about 700 horse. Any suggestions on what heads and all that i need to look into... As of right now im looking at buying a nice set of pistons and rods... Just dont know where to start after that. I see alot of post on different heads so i was kinda curious to see what peeps thought...
any help is appreciated!
thanks
justin
Old Nov 23, 2008 | 11:39 AM
Black FormulaLs1's Avatar
something had to make it go fast.......
Old Nov 23, 2008 | 03:33 PM
drewwrxrogers's Avatar
Haha....^
Old Nov 23, 2008 | 06:10 PM
black01_WS6's Avatar
look into the 317 heads for boost- cost effective and work. Partiot peformance, or TSP are good to start with. You can cheap out a bit on rods, just make sure they have the ARP2000 bolts in. The main concern is the pistons with Boost. You may want to stick with the major brands and also look into the different coatings now offered for the pistons.
My buddy has a 86 stang with a lq9 in it and it will definatly move out when he gets it done. He has also done a 93 stang swap.
start looking at the suspension. I know with the 4cy springs in the front the car still sits too high. Also I suggest getting a K-member that works with the ls1/mustang.
Old Nov 24, 2008 | 07:18 AM
LoNSlo02's Avatar
Yeah i was actually looking at a set of 317's. What kinda compression should i stay around for boost? I think im going to try and stay around 10-14lbs with this block till i get a cast iron one down the road. Im just trying to get this car going. It will also be a street car.
For suspension ive got a mini tub kit for the rear and a narrowed 9"... but the front ill be buying a AJE Racing crossmember... ill have to post some pics once i get going. Just looking for a little info on the LS1 side.
Old Nov 24, 2008 | 05:31 PM
ya the AJE is a very good piece. The 317's will lower your compression to under 10.0 I can't remember the exact comrpression, but it ends up being good for boost. There are a lot of guys running these heads on stock 346 and hitting 10 pounds of boost. At that point it all comes down to tuning. Really anything over that is just a bomb waiting to happen.
Old Nov 24, 2008 | 06:32 PM
LoNSlo02's Avatar
so will i need to run stock head gaskets? and not mill the heads or anything like that and my comp raito will be alright? What cc pistons would i need to run. Im looking at some diamonds. for the car... and ill prob. got with eagle rods with arp 2000 studs for my bottom end.
Old Nov 25, 2008 | 04:06 PM
If you go with a built motor- at least pistons. then you can mill the heads as you can take down the compression in the pistons. If you only replace the pistons make sure you change out the rod bolts to the arp 2000 or katec rod bolts. The eagle rods with the upgraded bolts will work just fine.
I would give some of the engine builders a ring for what they reccommend- TSP, EPP, speed inc. come to mind that have built some motors for boost.
The stock MLS 5 layer gaskets will work just fine, and are actually pretty good. also get some head studs.
