Those of you with MS4's...
I used all the factory sensors and everything but the head bolts were just a easy swap. make sure to get the head bolts for a 05 and up lq9. Also I had to do a little bit of beating on the windage tray to get it to fit without hitting the rod bolts
on ls1's the head bolts are three different sizes the two on the front and back inside corners I think are 60mm and the rest are 100mm and the like 20mm outside bolts and on 05 's and up they are all 60mm plus the inside 20mm bolts or whatever they are just order 2005 head bolts for lq9 and you should be fine.
Brandon
Brandon
