Replacement Lifter Suggestions
However, we discovered the engines set of OEM LS1 lifters have been misplaced. I'd planned to use OEM as OEM is working very well in my 99 T/A. I've read several threads about lifters etc.
The new engine is a mild 382 build that will see at most 6,600 rpm. Ramp rate for the cam will be XE-R or very similar. Spring pressure is in the 140 to 350. This is going in a daily driver car so the lifters need to be able to live for long time. Stock like longevity is required.
I think the LS7 lifters would be a good replacement?
I'm open to other suggestions too.
The Morel or similar are too much $$$ for my budget.
The Caddie 7K rpm lifter are having issues cracking under certain high lift circumstances as they slide up too far in the lifter bore and "chafe" against the sides. Plus they are more expensive anyways
The LS7 lifter is now the stock replacement lifter, its replaced the LS1 lifter from GM..They work great in my engine..
