More aggressive version of Cheatr cam?
Old Dec 4, 2008 | 03:25 PM
Formula51's Avatar
Default More aggressive version of Cheatr cam?
Hey guys.
I have a 2002 Z28 6spd and I am looking to do a cam swap based on the cheatR cam from TR. I will be keeping the stock manifolds and y-pipe for ground clearance, heat, emissions, etc. I am not opposed to replacing the cats with the Mufflex pipes, but want to be able to put the cats back in if I need to.
The car has an SLP lid and SLP loudmouth exhaust.
This car is a weekend driver and HPDE (roadcourse) event car. It might see the drag strip once a year if that. I am looking for some custom grind specs using the Cheatr as a starting point. I want to make sure I keep good low and mid-range power for exiting corners and enjoyment on the road. Stock redline is fine for me, but I am certainly not opposed to spinning a little higher, like the 6800rpm on the Cheatr. The biggest difference is that I do NOT want a stealth cam. I do want to keep the car very reliable and drivable, but I WANT the lope.
Goal is a streetable 380+rwhp through stock manifolds and y-pipe.
Cheatr specs: 214/230 .601/.575 117 LSA.
Old Dec 4, 2008 | 03:38 PM
ls1leadfoot's Avatar
get a custom ground cam from speed inc and get a diff lsa
cam specs are rather unique.....might be a hard goal to achieve...
F*ck it.....get a ms4
lol j/k
Old Dec 4, 2008 | 04:04 PM
Formula51's Avatar
lol j/k
I think it may be a hard goal, but I am hoping some of you gurus can get me pointed in the right direction as far as custom specs (i.e. duration, lift, LSA, etc.) or tell me who to talk to. There just isn't much data on something like this from what I have found.
I am basically trying to make the Camaro equivalent to the C5Z06. My weight is already close to 3300 lbs. so a little more weight reduction and about 380rwhp should pretty much get me there.
Old Dec 4, 2008 | 05:23 PM
PowerTalk's Avatar
Go LS6 cam and 243 heads instead?
Old Dec 4, 2008 | 05:37 PM
isenegger's Avatar
pm patrick g have him spec you one
Old Dec 5, 2008 | 06:46 AM
LustrousWS6's Avatar
The whole thing with the Cheatr cam is it's meant to work with the AFR 205's. Pair those two up and you'll have your goal. Lope can be found pretty easily i'm sure
Old Dec 5, 2008 | 12:46 PM
on2's Avatar
on2
I concur. That's what I did.
Old Dec 5, 2008 | 12:55 PM
jmilz28's Avatar
You didn't mention budget, which is #1 key.
That said, grab the AFR205s, a FAST 90 or 92 combo, and your CheatR cam or an LS6 cam. Bet you a dollar you see your goal with a good tune...especially if PatG can spec you something special.
Good luck!
Old Dec 5, 2008 | 12:56 PM
djsanchez2's Avatar
The Stealth cams (I & II) from MTI work pretty good.
I. - .220/.220 .581/.581 115lsa
II. - .224/.220 .581/.581 116LSA
Old Dec 5, 2008 | 01:29 PM
KMS.1320's Avatar
How agressive do you want to go? How worried about seat pressure (and to an extent collapsed lifters) are you? Do you mind changing your valvesprings every year or every other year as maintenance?
I can send you contact information in a PM for someone who can spec you a cam to meet your goals and have it fit your wants and needs if you're interested.
Old Dec 5, 2008 | 02:03 PM
TRANS-DAD's Avatar
I'm not sure why your working off the cheater as a base line ? if you wan't low to mid power and don't mind a chopy idle a 224/228 - 581/588 on 112+2 will make alot of power
even with stock exahust and drive very nice w/m6
Old Dec 5, 2008 | 02:34 PM
Formula51's Avatar
Good luck!
Budget is in the $800 to $1,000 range for parts.
I figure custom grind cam, Patriot Gold Springs, chomemoly pushrods, LS2 timing chain, gaskets, and perhaps a ported throttle body if necessary. From what I have read, I do not need to change lifters and I should be able to use my stock oil pump since the car is a 2002 and that means it is the LS6 pump?
I want to keep the stock heads.
Old Dec 5, 2008 | 02:37 PM
Formula51's Avatar
From everything I have read, the Cheatr was specifically designed for stock exhaust manifolds and this is why the exhaust duration is much longer than the intake duration. It also has some pretty high lift and I am not exactly sure why that is.
The 224/228 you recommended has a MUCH smaller duration split, which I believe means I would need a better flowing exhaust to take advantage of this cam. Essentially, it would not be as maximized for my exhaust as the Cheatr cam and thus could make less power. Does this sound correct?
Old Dec 5, 2008 | 02:40 PM
Formula51's Avatar
I do not want to get crazy aggressive. Remember that I want to maintain reliability and drive ability. Changing springs every other year is not what I had in mind. I was hoping to get more like 30,000 to 40,000 miles out of the valve springs. I hear this is pretty normal with Patriot Golds.
Old Dec 5, 2008 | 02:45 PM
slow ride 02's Avatar
I am with this guy! KMS 1320 you PM me with that info, if you dont mind.
Old Dec 5, 2008 | 04:29 PM
KMS.1320's Avatar
pm'd both of you
