what heads would u recommend to use with torquer v.3
Old 12-06-2008, 01:13 PM
02 T/A 984's Avatar
Default what heads would u recommend to use with torquer v.3
id like sum heads nothing really expensive preferably not over $1500 want a head for some good down low power to go with my torquer v.3
Old 12-06-2008, 01:36 PM
TXZ28LS1's Avatar
since you running a texas speed cam, why not just get some heads from texas speed. they are the ones to design that cam, so they will know what works.
Old 12-06-2008, 02:15 PM
02 T/A 984's Avatar
anyone else?
Old 12-06-2008, 02:57 PM
tnmotown's Avatar
i would guess tsp's 5.3 heads. i've seen some nice numbers with those combos
Old 12-06-2008, 03:29 PM
black01_WS6's Avatar
get the TSP 5.3 or their ls6 stage 2.5's with a 59cc and you will be happy.
make sure to check ptv clearance. all motors are a bit different and you shouldn't have a problem, but it will be close.
Old 12-06-2008, 06:16 PM
SweeTbone's Avatar
I went with the PRC 5.3 Stage 2.5s and am very happy with the results. Fiending to get to the track.
Old 12-06-2008, 08:10 PM
TXZ28LS1's Avatar
cool man... im looking at the PRC 5.3 heads as well
Old 12-06-2008, 08:14 PM
02 T/A 984's Avatar
im just scared by putting these heads on im going to just destroy the rear end even thou the car will never be launched or have sticky tires
Old 12-06-2008, 09:05 PM
ksk1980's Avatar
dont worry about the rear end being destroyed by a bigger cam / heads .its gonna happen anyways . I've torn out 4 10 bolts w/ regular street tires and my motors stock. so consider your rear on its last leg anyways . only reason i keep going back w/ a 10 bolt i can get'm cheap as hell. but i swear the 1 i have now is the last i'm messing w/ . it gets annoying having to be towed home on a roll back 1-2 times a yr.
Old 12-06-2008, 09:34 PM
02 T/A 984's Avatar
you really do have a great point on the rear end......but with cam only it's been goin strong for almost a year and a half
