MTI Introduces New Stage IIE Cylinder Head!
Old 09-25-2003, 04:17 PM
42NightZ28's Avatar
Default Re: MTI Introduces New Stage IIE Cylinder Head!
Thank God! maybe we can get a price war going between the Sponsors for even better head prices!
Old 09-25-2003, 04:26 PM
01_SuperSlow's Avatar
Awesome! That's a lot less than their original stage 2's.
Old 09-25-2003, 04:35 PM
oOoLy's Avatar
Very nice price
Old 09-25-2003, 04:46 PM
Blk00WS6's Avatar
Very nice Price. I know who i'm buying from as soon as you release the Stealth cam 2
Old 09-25-2003, 08:45 PM
David N's Avatar
Is stock compression ratio maintainted? Can one get Stage IIE with stock compressiom maintained?
Old 09-25-2003, 09:05 PM
beardWS6's Avatar
Nice price and good flow numbers. MTI has proved they are the best in the business! Jayson and crew are always trying to make it better for us LS1 owners! Thanks Jayson, now if we could get that 422 stroker price down I would love that!!!!!
Old 09-25-2003, 09:48 PM
wicked 98z's Avatar
David u got to much money Hows the car running? I havent seen you around town
Old 09-25-2003, 09:54 PM
Cheatin' Chad's Avatar
What are the final port and combustion chamber volumes?
Old 09-26-2003, 01:16 AM
bodhi's Avatar
how is "new" guides and bigger valves worth $1200?
Old 09-26-2003, 09:07 AM
MTI
MTI's Avatar
how much w/o cores?
-Steve
The $1595. is an exchange price for any aluminum Gen II head.
Old 09-26-2003, 09:10 AM
MTI
MTI's Avatar
How much would the LS6 head run for with LS1 cores.
We cannot accept LS1 cores for LS6 heads even at a higher price. If you can find LS6 heads at a cheap price get them and send them to us for full Stage IIe upgrade. If you need cores from us, we sell them at our cost which is $1200. delivered.
Old 09-26-2003, 09:12 AM
  #32
MTI
MTI's Avatar
MTI will build your cylinder heads uncut or cut them to your desired compression.
Old 09-26-2003, 09:29 AM
  #33
ONEBADWS6's Avatar
What do they flow through a LS6 intake?
MTI? Hello? What do they flow through a LS6 intake?
Old 09-26-2003, 09:32 AM
  #34
LS1Tech Co-Founder
Nine Ball's Avatar
MTI doesn't flow test their heads with an intake attached. Why would those numbers matter anyways, its not like we have another alternative intake to put on right now. Stock LS6 intakes flow about 265-270 cfm
Tony
Old 09-26-2003, 09:33 AM
  #35
PacerX's Avatar
LALALALALA!
Doubters, I FOOKING TOLD YOU SO.
MTI - way to step up to the plate!
Old 09-26-2003, 09:51 AM
  #36
ONEBADWS6's Avatar
They matter because thats what the motor see's and some heads suffer reversion with the intake attached. If the intake is only good to 265-270 how can Absolute Speed get 282 through one? Flow #'s mean nothing without the intake attached. And like MTI doesn't have 50 LS6 intake lying around and there own flow bench? 30 min of work with available parts can tell us a lot.
Old 09-26-2003, 10:11 AM
  #37
00T\A's Avatar
MTI Rocks Quality,Reputation,an a good price to boot.
Old 09-26-2003, 06:54 PM
  #38
Iv_z28's Avatar
So it looks to me like MTI stage I were replaced with stage IIe. As far as I remember stage one had the same valve sizes as this stage IIe. Would it be possible to elaborate on what the difference is?
Old 09-26-2003, 08:06 PM
  #39
LS1Tech Co-Founder
Nine Ball's Avatar
Its not like MTI is some new shop that hasn't already proven the quality and performance of their products. The first car dynoed with these heads put down some impressive numbers. The flow numbers presented were flowed in an identical test method as all of their previous heads and presented flow numbers. The port designs haven't changed any, and the same porters still do the hand-porting. Numerous dynos and track times out there have backed up their products. So really, do your LS6 intake flow numbers really need to be known? Personally, i'd rather know the track results and dynojet numbers, not flow number junk. I sure wouldn't buy a set of heads based on flow numbers alone.
Tony
Old 09-26-2003, 08:09 PM
  #40
Scalpel's Avatar
I agree with Tony. MTI's heads are tried and proven regardless of any intake used.
