which cam to get?
Old Dec 7, 2008 | 11:58 AM
97BlackLT1TA's Avatar
I have the TRex in my car and its not bad at all. It's an A3 so there is some difference there.
But even when it was a 6 speed I didn't have to downshift from 6th to pass or go up a hill.
Old Dec 7, 2008 | 12:02 PM
dubrado's Avatar
Originally Posted by 99blancoSS
And I really did mean best best of luck, LOL I wasnt being a wise ***
no worries man, thanks for the input and help.
Old Dec 7, 2008 | 12:24 PM
66deuce's Avatar
Big cams other dont make real power until 4000+ rpms. They start coming to life at 3500- rpms but you dont see *** kicking power until you hit the upper rpms. I would say from 4500-6600- rpms is where those cams really come to life.
Thats not good with a heavy car.
Do yourself a favor and have a cam speced for you. Cam size and compresion are not bragging rights, how fast the car is matters.
You will get a lot of misinformed opinions on here and hero worship from kids that do not know this difference.
Thats the best advice I can give.
tha'ts the best advise you'll get here..
get a cam matched to the weight and gearing of your car.your looking to make the most average power in the rpm range you'll be in..
even on the strip,
Old Dec 7, 2008 | 01:07 PM
Detoxx03's Avatar
I would suggest talking to a sponsor and getting a custom grind for you needs
Old Dec 7, 2008 | 06:24 PM
Spectre86's Avatar
Originally Posted by JJD49
you should contact one of our sponsers for help. I am sure they will be able to help you pick out the best one for your application.
P.S. I am running a big cam in my car [ 646 lift ] ,
saw the video in your sig. sounded like it had a nice lope for the 1st 6 seconds. whats the specs on your cam?
Old Dec 8, 2008 | 09:47 AM
BIGB4015's Avatar
I like the set up ms4+200 shot. Good luck with build.
Old Dec 8, 2008 | 01:16 PM
blubox's Avatar
Were the charts of the LS6 w/MS4 of a Vette, F-body, GTO? Wonder what kind of difference in power you'd see with the different variables and weights? Not really between F-body/GTO but if it was a Vette.
Old Dec 9, 2008 | 02:39 AM
BIGB4015's Avatar
Have you considered the megadeath from Hpe? Its up there with the ms4 and the Trex the reverse split is designed for max power with stock heads and intake to compinsate for air restrictions. I am running it and im making like 325tq @ 3000rpm not bad for stock heads,intake and catback. The specs are 244/242 .612 .610 112lsa. I am about to see how it likes a 150 shot/nano. I will try to dig up my dyno sheet so you can compare it.Also a 3.91 wouldent be a bad idea it would give it a little more ***** red light to red light
