pros/cons of running bigger injectors
right now i'm cam only ~400rwhp with stock injectors.
i know i'm not maxing out the duty cycle on the stock injectors, however i plan for heads in the future.
but for now, assuming the car is tuned for them, will there be any advantages to running the bigger injectors. i'll obviously be running them at a pretty low duty cycle.
is this a bad thing? should i just wait and run the stockers untill i get heads then swap them out?
i plan for a retune after swapping the intakes (and bigger injectors if possible)....cause it NEEDS IT BAD!
and i'd obviously retune after heads, but those may be over a year away.
and who knows...in enough time, i may build a stroker for the car. will be nice to have ONE set of injectors that will accomodate almost any setup
not bad for $1220 shipped
and after i sell my ls6 with ported TB....it should be about $900 total out of pocket.
so they are pretty much a steal...considering the intake and TB cost about what i'm paying.
I'd stay away from 50# injectors short of a power adder. Even a stroker should be happy with 36 or 42's the 50's are over kill.
I plan on use the 28.8# 02 stock injectors on my stroker. I'll let them spray at 100% or 105% the few seconds the engine is at high rpm & max output.
i don't plan to use them untill i get heads. and i MIGHT consider trading them out for smaller ones and get some cash back.
that's all down the road.
