View Poll Results: Which Cam?
Torquer v2
8
19.05%
Torquer v3
7
16.67%
Neither
27
64.29%
Voters: 42. You may not vote on this poll
Convince me!!
Old Dec 11, 2008 | 05:23 AM
TheLSgun's Avatar
Originally Posted by RedneckTA
Not really related to the OP, but I've been looking at h/c packages. I'm in a completely stock 98 TA right now ('bout to get the Rumbler in a couple weeks) and money is kinda tight right now so I can't afford both the heads and the cam. Should I hold off and wait til I can afford both, or do you guys think I'd be fine dropping the cam in and running it til I can afford the heads?
If I were you. I would hold off on a cam and get some more boltons. You need things like a lid, headers, ls6 intake, etc... To really get the full potential out of a cam.
Any who, if you decide to go cam, It would be OK to run cam for awhile. There are plenty of people with running a cam on stock heads.
Old Dec 11, 2008 | 05:24 AM
TheLSgun's Avatar
Now I see most of you guys are recommending custom grind. The thing about that is i really would not know what to get. How did you all decide on what grinds you wanted.
Any input appreciated.
Old Dec 14, 2008 | 09:16 PM
chrs1313's Avatar
talk with predator z or patrick g...or read some threads on the custom cams...i like mine alot but everyone has their preference
Old Dec 15, 2008 | 02:51 PM
SOMbitch's Avatar
Originally Posted by bigfatls6
If I were you and you have a stock ls1 short block I would use the thicker mls gaskets because with the tv3 and 5,3 heads you piston to valve clearance will already be really close. It should be in the .070-.080 range with unmilled 5.3 heads unless you get the 5.3s with the ressesd valves.
^^^^^^^X2 LSA and advance will also have an effect on PTV but yes don't mill or run .040's with 5.3's and a TV2/3
