cam curious
Old Dec 15, 2008 | 10:52 PM
BluLS1's Avatar
okay thats kinda what i figured you were talkin about but i really wasn't sure.
Old Dec 15, 2008 | 10:56 PM
BluLS1's Avatar
Originally Posted by chrs1313
my cam 230 230 with .612/.591 lift on a 111+2 had 0.086 intake and .120ish exhaust...this is with stock mls gaskets and stock untouched 241 heads...
you wanna trade cams lol
Old Dec 16, 2008 | 08:07 PM
chrs1313's Avatar
i will have to pass on this one, mine is working to well
Old Dec 16, 2008 | 10:34 PM
01ssreda4's Avatar
very good advice. better safe then sorry.
Old Dec 16, 2008 | 10:43 PM
Goldfinger911's Avatar
Just to clarify, you dont measure at TDC. (Every cam will clear at TDC.) It is the 12-15 degrees before and after TDC where the PTV contact happens. Buy the proper tools and measure PTV. It is only a few hours of less of work and well worth it. recently did mine at -15, -12, -10, -8, -6, -4, -2, +2, +4, +6, +8, +10, +12 and +15. Doing this I got a really good idea of my cam profile and where the tight spots are. (I had just enough clearance to be safe with my cam duration and milled heads.)
if you dont wanna pull the heads get a checker spring and use it in the valve... bring the piston to TDC and with a micrometer measure the clearance...do it a couple times to make sure...
if pulling the heads i recommend just claying the piston...
Old Dec 17, 2008 | 04:43 AM
chrs1313's Avatar
yeah you got it i just said that to summarize...but you got the idea...
