Plans for new mods on firehawk
Thunder racing raptor cam:
comp cams 5/16" , 7.4 push rods
patriout gold double valve springs
manley ls1/ls6 double roller timing chain
ls7 lifters
ls2 lifter guide trays
ls1/ls6 modified oil pump
kooks lt w/ off road pipe
ls6 heads w/ valve job, slight bowl work, back cut valves
ls6 intake manifold w/ ported ls1 tb to match
replace all gaskets, seals, and bolts
dyno/tune accordingly
**** headers are going to jet hot coatings for ceramic coating
all work is being done by thunder........ Let me know spome opinions or anything i left out!!
big cam with good flowing heads. but i'd worry about the low end power, but that may not be what you're building it for.
and honestly, i think i'd spend the extra coin and get the ported FAST. with that big of a setup you'd probably gain 20hp over the LS6.
granted it IS another $1500
oh, and i didnt see injectors on that list.
So yeah, I'd go with a DOD oil pump and caddy lifters. You going to be driving it every day?
the car will be a dd for about a 3-4 months after work complete then strait to garage queen. it has been projected to get anywhere from 440-450rwhp when complete. i'm already spending 4300 after i purchased headers,intake,heads so my budget is almost tapped out.
i'm willing to bet the injectors will max out.
and that 440-450rwhp is a good estimate. depending on the head flow.
you can always add the FAST later and pickup that 15-20hp.
granted i'm on stock gears, but with the stud kit and rear end girdle...my 10bolt is holding 400rwhp.
and i ran 315 DRs for 2 yrs....and shifting with a VERY solid spec 4 clutch.
but yeah...either way you're on borrowed time.
now pardon me while i go knock on some wood
