cam/heads help
As for combos, go to the dyno section and start combing through.
Also think about what the intended use of the car.
Furthermore with the m6, you need to consider the rear if at the track, it has a whole different kettle of fish to race that car and even if it has Drag radials and suspension, its either will light up the tires or bog and possibly break the rear.
I guess you need to decide what the intended use.
Heads, check out AFR, trick flows, PRC's.
As said above a ls6 intake, dyno tune, hardened push rods, new oil pump, timing chain, and lifters. That will be most of your 3-4k budget.
