Heads on a budget
Old Dec 16, 2008 | 08:34 AM
jpalamar's Avatar
Default Heads on a budget
So basically I'm a broke college student but need more power.
I did some research and found out a few things and correct me if I'm wrong.
- 243 heads from an LS2 are direct swap
- 243 heads from a Z06 are but since the valves are slightly different the rods need to be replaced with the correct size?
- And 5.3 heads will raise compression but I don't know if I can direct bolt and use my stock cam.
Any advise would be good. Spring I plan on doing a custom cam and headers with a retune
Old Dec 16, 2008 | 09:30 AM
5.3LJimmy's Avatar
All three of those heads are a direct bolt on. If you are talking about buying a set of 5.3 heads in stock form they have smaller valves. My choice would be for the 243's without the light weight valves because it will be the cheapest option. You could bolt them on without worrying about buying new pushrods, which can then wait till you do your cam swap down the road. The 5.3 heads wtih some work done to them are very good, but stock for stock the 243's are the way to go.
Old Dec 16, 2008 | 09:47 AM
teke184's Avatar
if you go through the trouble of swapping heads...put the thinner gasket on them. boost compression a smidgen.
but in reality...for the cost of the swap...and the minimal gains from stock 243 heads....i would look for power elsewhere.
Old Dec 16, 2008 | 09:52 AM
greyghost4x4's Avatar
Banging some gears
nitrous is the best bang for the buck... if your not scared of it
Old Dec 16, 2008 | 09:53 AM
02b4ccamaro's Avatar
forget the heads and just put a cam in it you will get a much bigger gain for the money, any head in stock form will not be worth the time and money.
Old Dec 16, 2008 | 11:57 AM
shannon french's Avatar
i've got a set for sale for $150+shipping. 853 casting though
Old Dec 16, 2008 | 01:04 PM
BlackScreaminMachine's Avatar
Internet Mechanic
Id toss a cam in there if your looking for a good jump in power.
Old Dec 16, 2008 | 01:19 PM
5.3LJimmy's Avatar
Are they ported or something? Why would he want stock LS1 heads to replace his stock LS1 heads?
Old Dec 16, 2008 | 03:56 PM
vettenuts's Avatar
LS6 heads between the three. Lighter valves make for a more controllable valve train with lighter springs. Valves are only 0.025" longer (from memory) thus not a real issue. They can be had for a fairly reasonable price if you can find them.
Old Dec 16, 2008 | 04:05 PM
5_02ls1's Avatar
Default 1.89
smaller valve yes...however they flow damn near the same with the smaller lighter valve...226cfm vs 227cfm..and the exhaust #s are identical.....and the added bump in compression to boot...most look at the smaller valve and push the head aside,thinking the heads will not flow,when in fact they do....
Old Dec 16, 2008 | 04:34 PM
04gtod's Avatar
I've got a set of Livernois Motorsports Stage 2, 243 heads, 62cc, with PAC 1518 springs for sale. If you are interested PM me.
Old Dec 16, 2008 | 06:09 PM
Gregorya24's Avatar
www.advanceinduction.com
Old Dec 16, 2008 | 09:19 PM
VIPERBLUELX's Avatar
To read what's said on here you'd think GM would have put the almighty 5.3 head on all their performance vehicles. Funny how they never put them on anything performance minded huh?
Old Dec 16, 2008 | 09:25 PM
5_02ls1's Avatar
Default sigh.........
Old Dec 16, 2008 | 09:29 PM
maybe you should let GM in on your findings!
