JOE SCHUBECK LIFTERS "WHO'S USING THEM" NEED HELP!!!!
Moderator
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
I don't plan on going solid for a while, but I need the adjustment as I have had problems from the get go on these lifters but again I have had the non adj jesel's and have been shimming several times now and just getting tired of it..My spring pressures are not that extreme as I'm running a fairly small cam. I just want these lifters to work properly w/o having to go back in the motor to replace them with OEM comp R's or crains!!!! Do you think the Jesel adjustables will be o.k.???
IIRC, the spring pressure limit on the Sportsman rockers was such that with virtually any spring soft enough to use w/ a hydraulic lifter (Rev 1116's, Comp 918's, 987's, etc...) you'd be okay. Don't quote me on that, though... you'll want to double check it.
The adjustabilty really is a necessity with these rockers, though... as the heads get more miles on them, the valves will pound in the seats a little bit... even just a couple of thou is a big deal if it puts you into preload, though...
Moderator
Just spent 1K on the new Jesel's today!!! I'm getting the full race version that are lite weight and super strong!!! I hope they will clear up my preload problem with the lifters....Send me your number BurnOut!!!!
Moderator
Thanks Guy's for the help, I will install the new ones tomorrow and keep my fingers crossed!!!!!!
If anyone else want's to add something, then chime in....
Thanks!!!!
Thanks!!!!
Moderator
The car is fixed!!!! We installed them today and we set them about .003 to .004 cold and the car spun up to 7100-7200 rpm test driving it today..It blew off the drag radials...They look killer sitting on top of the heads..I like the tool steel shafts...Going to dyno it tomorrow....It just took a little time and some $$$$ but I think we got it now!!!!
![Burnout](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_burnout.gif)
![Driving](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_driving3.gif)
