5.3 crank in my LS1
Old Dec 21, 2008 | 06:05 PM
91ZLS6's Avatar
Default 5.3 crank in my LS1
Hey Everyone,
Trying to make sure im not way off on this. I want to use my 5.3L crank in my LS1 since the LS1 crank is damaged, and teh 5.3L crank i have only has 3k miles on it.
They have the same stroke, and everything else abotu them seems the same.
Planning to put the crank in, and finish assembling the short block tommorow, just want to make sure im not off on this.
Thanks!
Old Dec 22, 2008 | 04:01 AM
TireSm0ke's Avatar
Are you sure the stroke is the same? Im gonna say that it probably wouldnt work... but with ls1 rods and pistons? im curious about this too
Old Dec 22, 2008 | 07:15 AM
cellulis44's Avatar
the rear flange is thicker on a truck crank.
Old Dec 22, 2008 | 08:37 AM
68 RS Convertible's Avatar
*REGENCY* just posted this in another tread the other day, so give him credit for this info.
"4.8 = 3.27 stroke, 6.278 rod length, and 3.779 flat top piston"
"5.3 = 3.622 stroke, 6.098 rod length, and 3.779 dished piston"
Old Dec 22, 2008 | 12:27 PM
5_02ls1's Avatar
Default not on all
the 99-00 lq4 6liter had the thicker flange...all the other 5.3,5.7,and 6.0 cranks are interchangable...the pistons were the difference....the main difference is that the ls1 crank is gundrilled and the truck crank is not...if you are using stock pistons you will be fine...however forged pistons or rods will need balancing...
Old Dec 22, 2008 | 01:07 PM
cellulis44's Avatar
ahhh thanks for clearing that up
Old Dec 31, 2008 | 08:57 PM
bww3588's Avatar
so can i use my stock LS1 crank and rods in a 6.0 block with 4.030 bore?
Old Dec 31, 2008 | 10:51 PM
novaflash2002's Avatar
it will work, but youll need to get the entire rotating assembily balanced. the 5.7l pistons are much heavier than the 5.3l so it would give it a wicked internal vibration.
Old Jan 1, 2009 | 04:50 PM
bww3588's Avatar
i know, im building a 370 for now, untill i can afford a 408 crank and rods.
