degree cam?
Here's a link to the Powerhouse: LS1/LS6 Crank Turning Socket
I use paint to make my marks for reference. There is no magic in the adjustables, they just save time.
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
This maybe a dumb question but I thought I would ask anyways. Do you degree cams that are done in your shop. I am planning on have you guys doing my H/C swap and wonder if you guys would do this as part of the job. Or would there be another fee. Thanks for your help.
I used an adjustable timing set to make my life easier.
The most difficult part of degreeing the cam (for me) was getting the dial indicator secured on the valve-tip. Since the rocker mounts are radiused it really made it hard to get that thing secured. After 6 hours, though, I got the cam within .3 degrees of the right ICL...I was tired by then and figured it was close enough.
I'm sure there is some tool that could have made that easier...but I didn't have it.
basically if you get the car dyno tuned you dont need to degree the cam?
no no, it has nothing to do with the "tune" of the car. that is adj. the IGNITION timing, and fuel curves. changing the cam timing is a mechanical change. when the valves open/close relative to when the piston is at tdc. you can make them open earlier or later.
I found out all small parts to hold the dial indicator to the head can be ordered from one site, www.Mcmaster.com. The only difference is the 12mm tubing has an inside diameter of 9mm instead of 8mm.
