degree cam?
Old Mar 31, 2009 | 10:40 PM
  #61
Irocss85's Avatar
Originally Posted by Kurtomac
i had my cam doctored...spec was 108icl and the cam doc said 108....now if i install dot to dot what am i checking for?...sorry cam degree dumb here
your looking for 108icl then. that would confirm the rest of your setup is spot on too. if its a bit off, then you know, since you had the cam doctored, that something else if off.
Old Apr 29, 2009 | 11:03 PM
  #62
flintwrench69's Avatar
Well, maybe I screwed up by not degreeing my cam. I just installed mine without degreeing it. Seems to run pretty strong. I didnt know a cam could be manufactured a few degrees off. It seems like it runs good, think I should degree it before getting the tune done?
Old May 2, 2009 | 03:33 AM
  #63
darknessxyz's Avatar
Quick question for you guys. How can someone degree a cam WITHOUT cam card?
A friend just installed a F13 @112 LSA with LT, catted Y-pipe, LS6 intake, PnP TB, SLP lid and some stuff I forgot (NO UD PULLEY). After dyno tune he only has 368rwhp and run best 12.7@110mph.
Something seems wrong either the tune or the cam install. He doesn't have the cam card, so can he still degree the cam?
Old May 2, 2009 | 03:37 AM
  #64
Oh, my cam doesn't come with cam card also. However the seller gave me the cam spec like Valve Timing, Duration, Lobe-Center Angle, Intake Centerline, Valve Lift, Lobe Lift etc. Can I still degree my cam?
He also gave me this info:
Intake Open Close
25 BTDC 69 ABDC
Exhaust
76BBDC 24ATDC
What does that means?
Old May 2, 2009 | 06:56 AM
  #65
vsocks1's Avatar
As long as you have some basic information on the cam...that is CORRECT..... you can degree it! Most important is the intake centerline that it is supposed to be installed on. The other info just lets you verify valve events,lift, etc... if you so choose.
Old May 2, 2009 | 10:44 AM
  #66
Irocss85's Avatar
yeah if you look up the instructions you'll see the ICL is the variable that your making sure is where its supposed to be. you can also use lobe lift, and duration just to double check you got the cam you are supposed to have. but the real point it to make sure your intake center line is where it is supposed to be "installed".
By Brett Foote | 2026-06-04 05:00:17
