White smoke out exhaust/wet intake?
Old 01-05-2009, 03:03 PM
1fine69's Avatar
Default White smoke out exhaust/wet intake?
Well, about 3 months ago, I started noticing some white smoke out of the tailpipes, and it seemed to get worse until winter came. I pulled the intake manifold and throttle body off the car today, and the inside of the intake is noticeably wet inside - not puddles, but everything looks wet. Could this even BE antifreeze sitting in there? If so, where would it come from? The throttle body's antifreeze line doesn't seem to have a possibility of getting into the intake...or is it oil?
The motor came out of a 98 Z28 with 42,000 miles that had been hit in the front passenger's side - crushed the radiator and nothing further back. I have had to replace the water pump, alternator, and starter since the car started running again 6 months ago, and it sat, unstarted for 3 1/2 years.
Thanks,
-Adam
Old 01-05-2009, 04:26 PM
01ssreda4's Avatar
how often do you drive the car? i dont think there is any way for coolant to get inside the intake...
Old 01-05-2009, 05:07 PM
1fine69's Avatar
I was driving the car about every other day...now, it hasn't been started in months, the starter is out right now, too.
There is also quite a bit of carbon build-up in each of the intake ports on the heads...is this normal for a 42,000 mile motor? I would say the bottom half of each intake port is BLACK.
Old 01-11-2009, 09:14 PM
domestic disturbance's Avatar
well the throttle body does have coolant that runs through it, so if you have a bad gasket it is possible your sucking in antifreeze.... if i was you i would do the throttle body coolant bypass!
Old 01-11-2009, 09:56 PM
poolshark021's Avatar
The coolant passage in the tb is self-contained. If the gasket was bad you would suck air through it, but not coolant. Unless the tb is broken, there is no way for coolant to get in the intake. You are probably seeing oil in there because the pcv system is known for sucking oil into the intake. As far as the white smoke goes, it may have another issue such as a bad head gasket or a cracked head.
Old 01-12-2009, 01:53 AM
Red96TA's Avatar
If your coolant level never depletes, then the white smoke is just condensation built up in the motor that is being expelled through the exhaust upon startup.
Old 01-12-2009, 12:12 PM
1fine69's Avatar
Can it really be that much though? I let the car sit and idle for 10 minutes and it was still spitting some out at idle, and significantly more above idle?
Old 01-12-2009, 12:21 PM
dre2013's Avatar
have you noticed any coolant-loss? and coolant in the oil or vice versa? and misfires at all?
Old 01-12-2009, 04:33 PM
Camaro Jearmy's Avatar
have you checked the plugs to see which cylinder has the water?
Old 01-12-2009, 06:03 PM
elgp's Avatar
what about the intake or head gaskets have you checked it
Old 01-12-2009, 08:39 PM
Red96TA's Avatar
On a cold morning mine looks like I sea foamed it. But I have no coolant loss. Check your EC level
Quick Reply: White smoke out exhaust/wet intake?
