ms4 what pushrods
Old Jan 7, 2009 | 06:46 PM
00silverGTP's Avatar
Default ms4 what pushrods
I have a chance to pick up a used ms4 with TSP 7.350 pushrods. I still have stock heads with ls6 intake. will those pushrods work? will I need to cut my pistons? thanks
Old Jan 7, 2009 | 06:52 PM
ABQ99TA's Avatar
You won't need to cut your pistons but those push rods are too short.
push rods are about $110
http://www.texas-speed.com/shop/item...d=152&catid=51
Old Jan 7, 2009 | 07:12 PM
bummer. do I need pushrods?
Old Jan 7, 2009 | 07:18 PM
00pooterSS's Avatar
Yes but longer ones, the ones you posted are shorter ones by .050, you need to go the other way, 7.450
And as far as PtoV clearance I think if you are stock deck and gasket it will make it, but I am NOT positive on that
Old Jan 7, 2009 | 07:22 PM
500hpZ06's Avatar
Texas Speed is pretty good about designing/phasing their camshafts to work on stock LS1/6 longblocks, with stock pistons and rockers.
I would think you may need a little longer pushrod, maybe 7.400" or 7.425". John J. at TSP might know right off the top of his head, if you call and ask him. Most (but not always) stock combinations are becoming fairly predictable when it comes to pushrod length when using these more common or well known cam grinds.
If you don't have an adjustable pushrod for checking/confirming length, I believe the "rule of thumb" is to have between ONE to ONE AND A HALF turns after ZERO LASH (the point at which all pushrod 'wiggle' has been taken away at the lifter plunger AND rocker arm) when 'bottoming out' the rocker arm bolt on the BASE CIRCLE of your cam. Less than that, and you need a longer pushrod. More than that, and you need a shorter pushrod.
I have some 7.450" Comp Cams, if you need them.
Old Jan 7, 2009 | 07:25 PM
00pooterSS's Avatar
the stock ones are already 7.400" and the base circle on the MS4 is smaller than a stock cam, so therefore you need longer pushrods.
Old Jan 7, 2009 | 07:56 PM
yeah I knew what the stock length was. I just didn't know if the shorter ones will work. thanks for the info.
Old Jan 7, 2009 | 07:57 PM
500hpZ06's Avatar
Yeah, I ran TSP's 233/239 (a couple steps down from the MS4) with 7.450" pushrods (that's what TSP recommended, and that jived with my adjustable pushrod and # of turns past zero). But this was on a 2001 LS6, so I wasn't sure if the valves or cam base were different from LS1 stuff.
I later ported and decked my heads, so I went to a shorter pushrod. My 7.450" Comps only have a couple thousand miles on them.
Old Jan 7, 2009 | 08:40 PM
how much you want for your 7.45s?
Old Jan 7, 2009 | 08:59 PM
500hpZ06's Avatar
I want to say they were about $120-$130 new...
so I would sell for...
$80 Paypal and Shipped UPS.
Upon inspection, if you don't like them, you can return them.
But you should make sure that is the length you need, first.
Old Jan 7, 2009 | 09:39 PM
Gordon0652's Avatar
Texas Speed Hardned Push Rods Factory Length.
Old Jan 7, 2009 | 10:41 PM
Jason 98 TA's Avatar
LS1Tech Premium Sponsor
We stock & offer both the 7.400" & little bit longer 7.425" length pushrods. I would not try the 7.450" length, the 7.425" length is just about the max.
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old Jan 7, 2009 | 10:54 PM
5.3LJimmy's Avatar
Don't forget about a good dual spring to keep that cam in check. I haven't seen any mention of that yet. The 7.45 pushrods will probably make your PTV clearance a little to close for comfort.
Old Jan 8, 2009 | 08:17 AM
yeah I had already planned on the springs, timing chain, and oil pump.
Old Jan 8, 2009 | 10:44 AM
evangto87's Avatar
lets say ptv clearance isnt an issue. What would u recomend then? Ill be running stock heads for a few months until my build is finished so im curious
Old Jan 8, 2009 | 11:05 AM
Sales2@Texas-speed's Avatar
Stock length is actually a bit shorter than 7.400" guys. FYI.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Jan 8, 2009 | 04:09 PM
what size do I need for the ms4 with stock heads?
Old Jan 8, 2009 | 04:15 PM
7.400" should do the trick!
__________________
Old Jan 9, 2009 | 06:52 PM
00pooterSS's Avatar
if you dont mind what is the actual length?, I was under the impression that the stockers were 7.400 and and most aftermarket cams are .050 smaller in diameter, is that correct?
