Finally Ordering Parts
Old Jan 9, 2009 | 06:24 PM
TheLSgun's Avatar
Default Finally Ordering Parts
Well guys here is the list of parts I'm ordering for my car. What do you think:
Already bought:
- stock LS6 243's (Should I get them ported?)
Ordering Soon:
- Torquer v3
- PRC Springs Kit
- TSP hardened push rods 7.40"
- TSP ported LS6 oil pump
- Basic Heads & Cam gasket/bolt kit (Cometic head gasket 0.040")
- LS7 Lifters
- LS2 timing chain
Am I missing anything?
Does everything seem compatible?
Thanks
Matt
Old Jan 9, 2009 | 07:27 PM
LS1MCSS's Avatar
I think I would have waited on the pushrods. You are going to a thinner head gasket, so you'll probably need shorter pushrods. Order a length checker, so you get the correct length the on the first order.
Old Jan 9, 2009 | 08:30 PM
formula4437's Avatar
possibly some bigger injectors
Old Jan 9, 2009 | 09:10 PM
devinfbody's Avatar
Lifter trays?
I'm in the same boat you are, hope i don't forget anything.
Old Jan 9, 2009 | 11:15 PM
TheLSgun's Avatar
Ya. I'm definitely gonna need injectors before i get a tune.
Old Jan 10, 2009 | 11:24 PM
TheLSgun's Avatar
Where to get lifter trays. The autoparts store?
Old Jan 11, 2009 | 04:43 AM
LS1MCSS's Avatar
Get them here.
http://www.sdparts.com/catalog/lsgen...IILifters.aspx
Old Jan 16, 2009 | 09:03 AM
TheLSgun's Avatar
Any other input on compatibility.
Old Jan 16, 2009 | 09:11 AM
devinfbody's Avatar
Also, I'm 90% sure the ls6 heads have center bolt valve covers, and your 98' has parameter ones. so... you're going to need new-style valve covers, you should double check that to make sure. Yes, get your heads ported.
Old Jan 16, 2009 | 09:24 AM
TheLSgun's Avatar
Yes, i know i need to get center bolt valve covers and coil brackets.
Old Jan 16, 2009 | 09:30 AM
streetassasin's Avatar
I would go with the Katech C5-R timing chain, they are having a sale right now $112 IIRC
https://ls1tech.com/forums/generatio...ing-chain.html
Old Jan 16, 2009 | 09:39 AM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
There's some inexpensive HP to be had from getting those LS6 heads ported! Give us a call. We can set you up with CNC porting and valve job starting at about $650.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Jan 16, 2009 | 09:49 AM
NC98Z's Avatar
Talking
You should be fine with the 28# injectors that your 98 came with. |I'm still running on my original injectors. When you go the Fast 92 intake is when you'lll need to get bigger ones.
