Z06 cam power increase?
Very true.................I have that same problem I was looking at getting a turbo specific cam, but ended up getting a used TR Cheater cam Saved some money to put back towards getting a forged short block.
But, if I had a free zo6 cam I would have saved more money and ran that.
i want to throw a Z06 cam in my 2000 T/A with patriot dual valve springs its for a turbo setup in a couple of weeks but for now how much power can i expect from the Z06 cam and patriot dual valve springs? i wanna do all the boltons and run it down the track and then boost it and see the difference so kinda trying to get a number here from the Z06 swap.. thanks
reason for Z06 cam it was FREE with 420 miles on it
they are the heads from the lq4/lq9 truck/suv motors..flow around the same amount as the 243's(ls6 heads), but will drop your compr ratio down in the 9's (not sure of the exact number, but i know LQ4's have 9.4:1).
Yeah, they are aluminum heads w/ LS6 port but with larger combustion chambers. They will bolt right up to a LS1 and should drop the compression ratio by almost a full point. The LQ4 had a compression ratio of 9.41:1 but it also has dished pistons. You can also run a thicker gasket to drop you CR a little more.
#33
204/211 .525/.525 116
'02-'04 LS6 cam:
204/218 .555/.551 117.5
As far as I know the '01 LS6 came with 243's just like the '02-'04 did, and the '01 LS6 is factory rated at 385hp and the '02-'04 LS6 is factory rated at 405 hp, so I guess the 20 hp difference is mostly due to the cam (increased exhaust duration and increased lift on both the intake and the exhaust).
#34
where did u find that? I read the 01 was 204/217
Oh well, still an improvement in the Ls1 world i suppose lol
How do you tell which 1 u have? Particular part # on the cam?
#35
'01 LS6 cam:
'02-'04 LS6 cam:
'02-'04 LS6 cam:
#37
^^ Can anyone help with that? Google isn't being too helpful for me
#39
[QUOTE=sujomatt;10846728]where did u find that? I read the 01 was 204/217
When I referred to cam profile,what I meant was that the cam lobes on the 02/04 are more aggressive,thus allowing the motor to rev quicker.
Check with GMPP for the part numbers...just click on the sponsors logo and go from there.
#40
[QUOTE=david vericker;10846833] Oh, gotcha.
