coolant ??
Old Jan 12, 2009 | 05:42 PM
f-bodyguy's Avatar
Default coolant ??
ive herd bad things about dexcool antifreeze, and ive also herd to run it in aluminum engines what do you guys have to say?
Old Jan 12, 2009 | 10:41 PM
Red96TA's Avatar
there is a humungous thread on this. search the official dexcool vs green thread or something of that nature
Old Jan 13, 2009 | 12:08 PM
ss.slp.ls1's Avatar
+2, it's been beat to death, FWIW, I have always run dexcool in both my '97 SS and '99 SS with no problems. Any antifreeze will work, some even just run water with water wetter.
Old Jan 13, 2009 | 12:19 PM
the_merv's Avatar
Veteran: Air Force
I run the green stuff.
Old Jan 13, 2009 | 03:57 PM
f-bodyguy's Avatar
alright i figurd there has been a couple and didnt feel like reading through all the b.s. so i figured some one would give short quick pros and cons thanks guys
Old Jan 13, 2009 | 04:02 PM
f-bodyguy's Avatar
i figured there was just didnt deel like reading throught the b.s.s figured some one would pro and con it but thanks guy
Old Jan 13, 2009 | 04:03 PM
vettenuts's Avatar
Dexcool is a superior coolant, stick with it. Just don't let it get low.
Old Jan 13, 2009 | 04:08 PM
ss.slp.ls1's Avatar
Ohh man, let the battle begin...
Use any coolant you want, just don't mix them.
If you convert from dexcool, make sure you drain and flush the whole system (not just the radiator) before you add the new green, yellow, (insert color of your choice) stuff.
Old Jan 13, 2009 | 04:20 PM
Hi-Po's Avatar
I use Caterpillar RED coolant. Great stuff. Good for 6000 hours on the machines.
Like said above, use whatever you want. Just dont mix ELC.
Old Jan 13, 2009 | 06:19 PM
LS199CAMAROZ28's Avatar
Their regular is purple!
Old Jan 13, 2009 | 07:24 PM
Hi-Po's Avatar
Purple? All I have seen in 3 + years is green and red. Red being the ELC.
Old Jan 13, 2009 | 08:38 PM
Yep. i work at the Cat dealer in Va. they changed from green to purple a couple of years ago.
