what do u think about this forged 346 boost engine build?
Old 01-13-2009 | 11:42 PM
Lawnboy's Avatar
Restricted User
Default what do u think about this forged 346 boost engine build?
did i leave anything out is there something you would have done different. It has been built for strength and reliablity, for some street racing .
This motor is going in a 01 SS M-6 street car with methanol injection and d1-sc, twin intercooled.
2001 LS6 M-6 SS CAMARO
MOTOR:
Built by Merkel Racing
Balanced/blue printed
LS6 block
Diamond Blower Pistons -8.6cc
Diamond Pro-Select Piston Rings
Heavy - Duty wrist pins
Eagle 3-D ESP H-beam rods
Callies DragonSlayer Crankshaft
DM Performance Main Girdle
SLP Double Roller timming chain
SLP High Volume oil pump
ARP main stud kit
King bearings
HEADS:
Absolute Speed Hand Ported
300cfm at .550
Ferrea Pro Flow Radius Competition Valves
2.00" Intakes 1.57" Exhaust
Crane dual Valve springs
Titanium retainers
Rocker Arms/Valvetrain
LS1/LS6 Harland sharp upgrade
Compcams High tech push rods
Pro magnum Lifters
Camshaft:
Thunder Racing Custome Blower Cam
215/231 .601/.574 116 LSA.
Old 01-14-2009 | 12:26 AM
PowerTalk's Avatar
Rod bolts?
What cr?
Sounds good
Old 01-14-2009 | 12:39 AM
Lawnboy's Avatar
Restricted User
yes ARP rod bolts, i think the CR falls in around 9.3 to one with the stock ported 241 heads i am running
Old 01-14-2009 | 09:10 AM
conan's Avatar
What head gasket are you going with? Every thing else sounds prety good... start saving for a big fuel system.
Old 01-14-2009 | 09:43 AM
Lawnboy's Avatar
Restricted User
i am using the GM MLS head gaskets, copper sprayed
