Oil Catch can
I used a norris catch can
http://www.pro-touring.com/forum/showthread.php?t=43918
Maybe it's both rings, and PCV in which case if you fix the PCV and add a catch can you can decrease the amount you burn. Until you can tear it down and fix the main problem..
I put a set of fab valve covers on my 402, ran a -10 line to connect them and then run to a moroso vent can, like what is used with a vacum pump.
It has been working pretty good for a year of 9 second passes.
