HELP! noob in the middle of head & cam swap
Old Jan 14, 2009 | 10:36 PM
bigftruck's Avatar
Default HELP! noob in the middle of head & cam swap
sorry about the nooob questions but i am inside a ls1 for the first time and need some questions answered. I am installing am ms3 cam on a 113 lsa and stage 2.5 5.3L heads that i purchased as a combo from tsp. Also purchased all new gaskets, new oil pump, ls7 lifters, pushrods. I have everything disassembled and i am ready to start putting it all back together tomorrow.
1. can i just soak the cam in engine oil or do i need pre-assembly lube.
2. can i break the cam in with regular oil and then switch to synthetic or should i start it with synthetic in it.
3. do the oiling holes in the lifters need to be facing a certain way or will facing toward the front or back not make a difference.(my stock lifters were all mixed and matched)
Thank you to anyone who can answer these questions and possibly offer any other advice i might need
Old Jan 14, 2009 | 10:44 PM
StreetSilverado's Avatar
LS1howto.com it helps.
http://ls1howto.com/index.php?article=2
Goodluck.
Old Jan 14, 2009 | 10:47 PM
Also I'd go for some "break-in" oil for 100 miles or so before putting in synthetic.
Old Jan 14, 2009 | 10:49 PM
bigftruck's Avatar
thaks man thats actually the site im using step by step but it doesnt answer these questions. thanks for the help
Old Jan 14, 2009 | 10:53 PM
jsteele90's Avatar
i just lubed my cam with some synthetic oil i had lying around. it was a used cam though. dont know if that matters. i would just use new oil after youre done with the cam swap with whatever you usualy fill it with. as far as the lifter tray oiling holes i duno
MrElectric03's Avatar
1.I just put engine oil on the cam lobes while installing it, as long as you are going to start it within a couple days or so it should be ok, assembly lube if the engine will sit for a while before being started.
2.I just kept synthetic, the lifters are rollers, you arent installing new bearings so it should be good.
3.I wondered the same thing...lol. I looked for hours, couldnt find an answer so I dont think it matters.
Hit me up if I can help out with anything else.
Old Jan 14, 2009 | 11:44 PM
bigftruck's Avatar
thanks guys i apreciate it ! Im prob just going to use regular oil on the cam i guess and run the car for 100 miles or so and switch to synthetic ( i have never run synthetic in it before) hopefully the oiling holes will be good facing the front
Old Jan 14, 2009 | 11:55 PM
johnLs1camaro's Avatar
yeah, i used a really thick stp oil, it cant think what it is called and just ran it around the lobes and what not and installed it. i also agree with everyone just use a cheap oil, because your gonna want to change it at the 100 mile mark.
Old Jan 15, 2009 | 12:07 AM
Oh well if you havent used synthetic yet then just use regular oil for sure
Old Jan 15, 2009 | 12:24 AM
bigftruck's Avatar
It looks like u have a strong setup there mrelectric. Im excited i hope mine puts down the power you have in your sig You have any track times by chance? By the way thanks for the help too
