who does the stock rocker upgrade?
Old Jan 15, 2009 | 10:08 AM
dubrado's Avatar
Default who does the stock rocker upgrade?
I want to have harland sharp upgrade my stock rockers to be stronger, do I need to go through them directly?
Old Jan 15, 2009 | 10:35 AM
ss.slp.ls1's Avatar
Most people upgrade their rockers to increase their rocker arm ratio, lighten up the valvetrain components, or both. I don't necessarily think its a strength issue. I have see gobs of power made with stock rockers.
Old Jan 15, 2009 | 10:43 AM
CamaroSS22's Avatar
People usually send them to harland sharp to get an actual roller bearing installed instead of the crappy needle bearings they come with. It gives you less friction and if one wears out its not going to send needle bearings all through your engine.
Old Jan 15, 2009 | 10:45 AM
ss.slp.ls1's Avatar
Oh, gotcha.
Old Jan 20, 2009 | 07:42 PM
dubrado's Avatar
cool, i'll call them about that.
Old Jan 20, 2009 | 09:48 PM
HavATampa's Avatar
$260 to send them in for the upgrade or $250 to buy the kit and do them yourself. Sounds like a no brainer I guess. Send them in.
http://www.harlandsharp.com/conversion%20kit.htm
Old Jan 20, 2009 | 10:00 PM
cws T/A's Avatar
Has anyone bought the kit and done it themself ?
Old Jan 20, 2009 | 10:06 PM
HavATampa's Avatar
Question
I asked this same question a few weeks ago and got 0 bites. I wonder if there is any machining involved or is it just a straight up pull apart and reassemble?
https://ls1tech.com/forums/showthrea...ferrerid=13535
