Low Oil Pressure????
Old Jan 16, 2009 | 10:28 PM
soonenough98's Avatar
Default Low Oil Pressure????
I got a 2000 ws6 and its stock with the exception of a lid. the oil pressure gauge is reading around 20psi @ idle...when i first got the car a couple of weeks ago it would idle @ around 40psi.......is 20 psi safe and or normal?.......thanks
Old Jan 17, 2009 | 01:44 AM
01ssreda4's Avatar
its safe but doesn't seem to be the norm here. at 100k mine still had 35 hot idle. i would say replace the pump. pressure springs get old and can bleed off pressure prematurely.
Old Jan 17, 2009 | 05:22 AM
DaddySS's Avatar
Was the oil freshly changed when you got it? What kind of oil did they use? What kind of filter?
20 lbs at idle is not bad, assuming it goes up to 40 while driving.
I would start with an oil change to quality oil and filter (AC Delco, etc. not Fram) and see what you have - check for any debris on the drain plug while you're at it.
Old Jan 17, 2009 | 08:22 AM
01ssreda4's Avatar
please dont let anyone tell you a 20 lb idle pressure is normal bc its not. i have read lots of oil pressure threads and most have 30-40 on hot idle, not 20. keep a close eye on it, oil pump pressure springs fail over time (in my experience) so you should be able to tell if its getting worse. if it was my car i would replace the pump.
Old Jan 17, 2009 | 09:47 AM
thanks man i think im gonna get a pump and some new oil.....are melling pumps from advance ok??
Old Jan 17, 2009 | 09:56 AM
the_merv's Avatar
Veteran: Air Force
I have a Melling HV Pump, good pump. Idles at 60+psi hot.
Old Jan 17, 2009 | 10:02 AM
01ssreda4's Avatar
i got a melling 295 which is a standard replacement pump from advance auto for about $105. exact same oil pressure as my original pump which was about 35 hot idle, 50 cruising and 70 WOT.
i dont think this one is high volume...is that still ok?
Old Jan 17, 2009 | 10:03 AM
thanks guys i appreciate the help!
Old Jan 17, 2009 | 12:10 PM
01ssreda4's Avatar
a 295 is standard replacement. a 296 is a high pressure and/or high volume
