ls2 heads?
Old Jan 18, 2009 | 04:48 PM
camaroracer91's Avatar
Default ls2 heads?
would switching my heads to ls2 heads make any more power over the ls1 heads on a bolt on camaro with possibly a cam in the future?
Old Jan 18, 2009 | 06:04 PM
Unertl42's Avatar
stock, or were you going to mill them down?
Old Jan 18, 2009 | 07:41 PM
depends on what people are selling, would stock ones make a difference
Old Jan 27, 2009 | 10:33 PM
GTOFan350's Avatar
I've been wondering this myself. My friend just totaled his C5 Vette and I was wondering if his heads and cam would fit my ls1?
Old Jan 28, 2009 | 12:26 AM
spray_goat's Avatar
a stock 243 casting would pick up a few ponies, getting them milled down to 59cc would make a little more but it will limit your cam choices due to ptv issues
Old Jan 28, 2009 | 02:52 AM
SOMbitch's Avatar
About 15rwhp is the number I see tossed about for a a stock valved no mill 243 casting.
Old Jan 28, 2009 | 09:29 AM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
That's about right for a stock 243 or 799 casting head. Cam selection will dictate whether or not you should mill the heads, and if so how much to mill.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Feb 3, 2009 | 09:52 AM
Bad G04t's Avatar
I'm planning on putting stock ls6 243 heads on my 04 ls1 gto
I have them down at the machine shop now and they are going to deck them for straightness anyway and i was planning on running cometic .051 gaskets, how much can i get them milled safely for a mild build (LPE gt2-3 cam) without getting into valve clearance issues, I don't want a crazy compression ratio, just a little bump in power since I'm using unported stock heads
would milling just .010 or .005 be worth it? will this effect my pushrod length?
