Need help bad! Multiple problems.
Old Jan 18, 2009 | 06:24 PM
camaroIroc's Avatar
Unhappy Need help bad! Multiple problems.
first off, i have a 1986 iroc z28. with a 5.3, and a built 700r4 with 3200 stall. my problems include high idle, studders, weak on power, and dies out.
my mods include Ls6 cam, Ls2 intake, 80mm tb, custom longtubes, egr! delete, Ls1 injectors..all tuned by PCMforless.
ive tried alot of different things, just looking for another option.
-i think i have too much stall
or
-i think iac sensor is bad
or
-tranny is bad
the hardest part about this is the fact that i dont have the dash harness, for my swap, so no dtc connector....for now that is.
any advice is appreciated.
Old Jan 18, 2009 | 08:42 PM
OUTLAWZ RACING's Avatar
Sounds like a vac leak some where, or T body is off adjustment. Is th t-blad complete shut was it drilled more info.
camaroIroc's Avatar
the blade is not drilled, i figured that would bring more rpm in idle...
Old Jan 18, 2009 | 08:45 PM
camaroIroc's Avatar
i meant to add, the reason i think my tranny is bad is because, the studder i feel is violent...its more of a shudder and buck.
Old Jan 18, 2009 | 08:54 PM
bad2dbone's Avatar
im thinking tuning OR vac leak
Old Jan 18, 2009 | 09:09 PM
camaroIroc's Avatar
i can give those things another look, and talk to my tuner. but what about the tranny? its not electronic, just the standard analog 7004. i just feel a load on the engine, that is more than usual, and it causes most of the bucking and shudders.
Old Jan 18, 2009 | 09:10 PM
stlcamaros's Avatar
Torque converter
Old Jan 18, 2009 | 09:17 PM
camaroIroc's Avatar
its a 2800-3200 stall, made by daaco.. should i pull it and try a stock one?
Old Jan 19, 2009 | 12:56 AM
blades11b's Avatar
sounds like many problems first you need to get into that computer and see whats going on... on another note i have an 86 iroc myself... mind sending me some pics of the build? im gonna do that swap soon after i get back from iraq.
Old Jan 19, 2009 | 01:49 PM
camaroIroc's Avatar
sure i will send pm. i also purchased a DLC pigtail harness from EFIconnections...so when it gets here i will be able to tap into the computer. my biggest concern is the tranny, i dont want to have to go through the removal and trying to get a refund..
Old Jan 19, 2009 | 08:21 PM
01ssreda4's Avatar
i thought the ls2 intake had a 90 mm opening??
Old Jan 19, 2009 | 09:20 PM
camaroIroc's Avatar
it does, but i cant afford one for this build, so i am using an 80mm. lol
